Results 1 to 3 of 3
Thread: Opus wiring: best method for running ground wires
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    I'm getting ready to run my wires in the car, and I'm wondering what would be the best method for running the ground (black) wires from the Opus (in the trunk) to the battery... Is it better to:
    1) run a 10AWG (or 8AWG) wire from the battery negative terminal to a distribution block in the trunk which would split into the 2 16AWG black wires on the Opus.
    2) extend the 2 16AWG wires to the battery and attach them directly?
    I'm guessing it would be better to run a 10AWG (or 8AWG) to the trunk, but just want to make sure...
    Also, where can I get a good price on a distribution block for this purpose? I would prefer a single unit with 2 distinct connections... 1 10AWG (or 8AWG) to 2 16AWG connections for positive (yellow), and 1 10AWG (or 8AWG) to 2 16AWG connections for the ground (black).
    [edit: the reason I'm saying 10AWG or 8AWG is because I haven't decided which yet. I might go with 8AWG to prevent the possibility of alternator whine on the audio]
    [edit: Also, for the pair of GROUND wires, is it safe to run the pair of 16AWG wires directly to the battery, or should they go through a distro block also? If they can go directly to the battery negative terminal, then I would only need a single 1x8AWG to 2x16AWG distro and not a dual distro block]
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
    May 2003
    why would you run the ground wire back to the battery?
    Jan 2005
    Just ground the negative distro block to the chassis in the boot using the same thickness wire as the thickest that you run for positive from the battery.
    twest17: if you are gonna bother replying then at least give the answer. Something isn't obvious unless you know it.
  1. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  2. What gauge wires come with OPUS and M1
    By buurin in forum Power Supplies
    Last Post: 11-04-2005, 08:43 PM
  3. Opus WIRING HELP!!!
    By mikeyg35 in forum Power Supplies
    Last Post: 04-15-2004, 10:59 AM
  4. Opus Wires Guage Help!
    Last Post: 04-04-2004, 08:29 PM
  5. wiring question about the opus 90w
    By DSM97RS in forum Power Supplies
    Last Post: 03-28-2004, 09:28 PM
