Results 1 to 7 of 7
Thread: ds-atx problem
    Apr 2006
    ds-atx problem
    i have a ds-atx psu running a k8ngm-v motherboard with a 1.8ghz amd sempron. when i start my car the led turns on and the processor fans spins for about ten seconds and then stops the psu led remains on. i never get a video signal just the keyboard lights stay on. when i turn off the car the led blinks twice and turns off. i have a switch installed currently so i can power up the computer with this switch. but there is no shutdown delay. the power supply just turns off. is it possible that this is because i am using a 20pin to 24pin adapter for the motherboard. i cannot think of anything else. any suggestions???
    Dec 2005
    Did you turn P2 to its lowest setting of 10V (fully counter clockwise)?
    I had the same problem where the cpu fan would turn on for about 5 seconds and shut off. The DSATX would still stay on but would not output any voltages.
    This is how I fixed it:
    You can also try reversing the 2-pin header on the motherboard switch (on JP1).
    Apr 2006
    yeah i tried that. made some changes on the brainstem and still no luck. also tried the switch relay idea, DSATX startup
    and still the same. here are the brainstem readings just in case
    DSATX:+031.1:14.09:00.05:00.50:00.06:11.50:1200:YY YN:2:0000
    Apr 2001
    Portland OR
    Quote Originally Posted by justplayin59
    Yaa basically that says that the computer is not on. Does it work if you use the power switch?
    Do you have the relay hooked up to Vin and the G1 pin?
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Apr 2006
    yeah it works with a regular switch and yes i have the relay hooked up to the g1 pin and the vin. will get a reading with computer on today.
    Apr 2001
    Portland OR
    Every time you hit the @ key it should send a pulse so you can test your relay. Is your relay clicking?
    www.mpegbox.com
    Apr 2006
    the @ key does nothing. and then if i check status it still always says running.
    Quote Originally Posted by zootjeff
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  2. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 11:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
