Congrats on your first post.
OK to answer the questions, here goes.
1) The sound through the speakers probably has something to do with the inverter. Most people here are going to say ge a DC-DC pwr supply, and while Id agree, there are a few thing to check first. Try powering the pc in the vehicle from an extension cable from your house. I doubt the problem will occur using mains power. If the sound is still there, try a different supply also.
2) Are you using on-board sound? Or a PCI card?
3) Auto shutdown controlers basically shut your PC down in a nice way. They generally keep the PC running for 5-10 minutes after you turn off your ignition, and then start the shutdown process. This does 2 things. Firstly if you get out of your car for fuel or whatever you wont have to boot up the computer when you get back in. Its still running. Great if your in and out of the car alot. Secondly it lessens the damage to your HDD. By just cutting the power some people believe you can creat bad sectors and such. I wont get into this again.....................its another arguement waiting to happen.
LinkBack URL
About LinkBacks
P! that is heard.
