Chopping a Sproggy
Any one think of any reason I can't cut a 2.6 Sproggy in half and join the traces with wire?
I've got a 2.5 running at the moment, with a laptop drive. The laptop drive has decided it doesn't want to play any more, so I'm thinking of replacing it with a standard 3.5" drive. To do this, I need a short, fat power supply, not a long thin one.
If I cut a pcb down the middle (between the 787 and 745, just to the left of the LED), and join the 6 cut tracks with 1" of wire, I could bend the psu in half, have a double-layer one, about 85mm long.
I'll mount this with all the TO220 parts bolted to the bottom of the case - use the whole aluminium box as the heatsink.
Before I do this and blow the whole lot up, could anyone point out the silly things i've probably overlooked...
I can see any reason why this would cause any problems, as long as you use nice thick wires, and be carefull to connect everything up correctly. But it might be a fair bit easier to built a custom PCB.
Rob
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
maybe, but i've got everything I need to chop the sproggy up already here. I haven't got the time or patience to redo to pcb.
Even easier than that would be a slightly bigger case. I'll do some measuring in a while, see if I can fit anything in better.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
