Results 1 to 10 of 20
Thread: Opus 150 Causing Drain or Bad Battery? Maybe 5vsb Issue?
    Oct 2005
    Hou. TX
    My specs are in the sig.
    2 weeks ago I got an Opus 150 and it's worked fine. During the week I drive the car every day and usually the off time is maybe 12 hours.
    2 weekends ago I started using S3 standby during the week and it was fine. Then the weekend came and the car was off for over 24 hours and it cranked OK. I drove it around and the next day it wasn't OK. The car wouldn't crank. So I switched to Hibernation. This last weekend I had the car off for 30 hours and it cranked, but seemed a little slow. The voltage was 11.8v before I cranked it. So after driving around I left it off for about 24 hours again. This time I checked the voltage at the 15 hour mark and it was at 11.8v which is OK. I then checked on it after another 9 hours and the voltage was 9.8v!
    How could it go down that low in only 9 hours?
    Why did the Opus 150 let it get that low?
    Won't the Opus turn off all power after 11volts? Or does the PC have to be running for it to do that?
    I don't have any USB devices, but the mobo might be drawing a little from the 5vsb. Maybe that little extra drain is causing a mediocre battery to start to fail? I really can't explain a 3v drop in only 9 hours.
    Do you think the battery is the problem?
    I load tested the alternator with a sophisticated computer. It was putting out around 80 amps hot and under heavy load. It passed all the tests.
    I'm going to try and run a battery test next.
    Does anyone think the Opus can be drawing a little too much current when powered down?
    Do you think I should mod the Opus to turn off the 5vsb, just in case?
    Would doing so still allow the mobo to use S3 standby?
    Any help would be appreciated.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
    Oct 2005
    Hou. TX
    Well, I tested the battery. The battery tester computer passed it the first time but I noticed that under the heavy load test the voltage got down to 9 something volts. So I decided to test it again without charging it. This time the voltage got down to 7.8 volts and it failed the test.
    So it seems like this battery is OK for everyday driving, but as it goes down it loses voltage exponentially. Which makes sense due the large drop from 11.8v to 9.8v in only 9 hours with the PC off.
    What a shame. My old battery was fine a month ago and then suddenly got an internal short and had to be changed. The current battery that I swapped in was from another car of mine I don't drive and was very reliable about holding a charge. Now it's going out too. Bummer.
    Anyone have any recommendations for a good battery? I think the Optima Yellow Top is my best bet considering I have a big sound system, but it is pricy at $150 and has a not so good warranty. Any other suggestions?
    Oh yea, the opus did shut down right at 11.3 volts. I was listening to it last night for about 20 minutes and it suddenly went into it's hibernation cycle. I thought I had bumped the key off of something, but I quickly glanced at my digital voltmeter and it was at 11.3. So I guess that Opus shutdown protection only works when it is running.
    Can anyone else confirm this?
    CarPC's in F-bodies
    Low Bitrate Pepe's Avatar
    Jul 2003
    Kingston, Ontario, Canada
    Yes. Simple solution. Put a relay circuit inline with the Opus main power.
    Problem solved.
    99 Ford Ranger - Bagged and laying frame
    Current Carputer project:
    Done:
    Custom mounted 7" LCD w/ TSK in radio bezel
    Custom center console for relocated headunit
    Via Epia M10000
    GPS
    MP3
    OPUS PSU
    DVD
    Oct 2005
    Hou. TX
    Quote Originally Posted by Pepe
    Problem solved.
    Nope, replacing battery.
    Cutting the main power will not let you use suspend and I plan to use it.
    CarPC's in F-bodies
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    The opus will drain your battery FLAT.. it has no protection against draining your battery whilst its turned off, it drains it by supplying your MB with a constant current even when off. The protection it does have is that it will power down your MB if its turned on and the car battery drops below a certain voltage.
    I went through 2 batterys with this.. I now run a M2 and i'm nearly happy.. lol
    CdR
    Oct 2005
    Hou. TX
    Do you know if the Opus protection circuit will work when the PC is in standby?
    I'm also considering a solar charger in the passenger site t-top panel. I wonder if it will work well through the tint?
    I'm also looking for a battery saving device. I haven't seen one in years, but they attach to the battery and monitor the voltage. They are like a smart circuit breaker. If it kicks in and cuts power to the car while in standby I think it will be OK as WN XP is pretty robust. Hopefully it won't be very often if at all. Anyone seen these devices?
    BTW, I went through 3 of the M2's and they all had something wrong with them. I finally went with the opus 150 and it fired up the first time and has been perfect. The only other choice I see would be the DSATX 220 Watt. Anyone know if it has the low voltage protection when off?
    CarPC's in F-bodies
    was Boston -> now Canada!
    Don't want to thread jack here but do all Opus' have this problem? I think the newer ones have a fix for this as I have the Opus 120 and my truck was parked for two weeks while on vacation, back in Sept, and I had no problems starting it at all. In January I was on a week long vacation and I also had no problems at all. I assume there is very minimal draw with the 120. I know this subject is talked about a million times but it sounds like all Opus' would do this by reading cdrskull's message.
    I was shutting down each time I turned off the ignition and I am now using hibernate which should be no different then a complete powerdown as far as the Opus is concerned. With standby there will always be draw on the battery but off course it should be minimal.
    Chuck
    Oct 2005
    Hou. TX
    Quote Originally Posted by JasonWW
    I found one! It 's called the Priority Start - Battery Power Saver.
    http://www.lingenfelter.com/store/17758.html
    It's a little pricey though. I don't like that it cuts power at 12v or the top mounts. I'll have to see if it will work for me and my application.
    CarPC's in F-bodies
    Variable Bitrate nkotch's Avatar
    Dec 2005
    FL
    In the manual it says it has protection from deep discharging of the battery. I personally just use Hibernation and have had no problems with mine. I bought mine from another user on here and he said he had it modded at OPUS to cut 5V power at shutdown so that is something you may want to look into. When you have it turned off put a meter on the 5V leads and see if there is still power there or not.
    Also, even though your alternator tested fine that one time, you may want to try again at different times or at least try another time or so if you have access to the equipment. I had some battery problems about a month ago. Went to the shop, alternator tested perfect the first time, replaced the battery, and it died again. Tested alternator again and it was "inconclusive", apparently they say that an alternator that is going bad can be weird, sometimes it may test fine, other times it may be on the verge of going..... kind of depends on when you catch it. Could also just completely disconnect the OPUS for a couple days and see if you still have battery problems.
    Nick
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Oct 2005
    Hou. TX
    Quote Originally Posted by nkotch
    I have, modding it will cause you to loose the suspend functionality. So I don't want to do that.
    I replaced the original alternator about 6 months ago because a bearing was making a noise. So I got a new factory alternator under warranty. When I had battery problems about a month ago the charging characteristics struck me as being fine. The battery shorted internally and constantly ran down even with no load on it, but I tested the alternator just to be sure. I work at a Pontiac dealership so I checked it with a GM computerized tester that can load it down while measuring the amperage it's putting out. You can't get much better than that. So I really don't think I have an alternator problem. I've rebuilt numerous alternators and know them inside and out, but I might check it again, just for the hell of it.
    I don't think I can go without music for that long. I'm using hibernation right now and since it's the weekend I may not drive anywhere for 24 or 30 hours, so I'll pull the power plug on it and see how it does. I know the PC is drawing some power, but I don't think it's excessive. I don't want to have to unplug the PC every weekend. I'm definately going to replace this battery and then I should be able to go back to using S3 suspend.
    It's a cheap Walmart battery around 3 years old so I'm not too surprised anyway. I'm just trying to decide what battery to get. There's Optima Yellow Top, Stinger SP1000, Deka Intimidator, Exide Select Orbital XCD or Odyssey 925.
    CarPC's in F-bodies
  1. Another Opus issue
    By 04scooby in forum Power Supplies
    Last Post: 04-09-2006, 09:17 PM
  2. Does M1 not prevent battery drain while PC is on?
    By uncrase in forum Power Supplies
    Last Post: 10-29-2005, 04:59 PM
  3. OPUS 150 watt DC-DC power Supply for sale
    By audia4carputer in forum Classified Archive
    Last Post: 02-27-2005, 01:20 PM
  4. Bad Battery or Bad Connection or Altenator?
    By sniz55 in forum General MP3Car Discussion
    Last Post: 01-30-2005, 06:40 PM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
