Results 1 to 4 of 4
Thread: 1970 Standard beetle, options for more power?
    Apr 2006
    Miami, FL
    I need more power. I have a standard beetle with a generator. Not sure what the output is but its not enough to power 4 speakers, 2 subs w/ 2 amps and a laptop..
    help?
    Apr 2006
    For a beetle, best bet is to drop the generator and voltage regular and convert to a alternator.. if you check they now have 95amp alternators for the bug... When my bug was running and I had the 95amp alt in it I was able to run over 2000watts of amps in it plus an empeg stereo.. I also put in a second battery in the other side of the back seat so I could run it all with the car off..
    Apr 2006
    Miami, FL
    I'll talk to my mechanic today when I go pick up the car..thanks!
    Apr 2006
    They also have lower alt kits like 75 amp... when converting from the gen youll need more then just the alt, youll need a stand as well since it sits slightly differnt then the generator. If your mechanic is unable to locate a kit for you check with socalautoparts.com that is where i purchased mine..
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Replies: 5
    Last Post: 09-26-2005, 05:18 PM
  3. What are the ATX DC to DC power supply options?
    By Squeezer in forum Power Supplies
    Last Post: 07-08-2002, 05:25 PM
  4. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
  5. Extra power options?
    By TheDingo in forum Power Supplies
    Last Post: 06-02-2001, 01:19 AM
