Shouldn't the M2-ATX automatically put it in hibernation for you?
i'm going crazy...![]()
when i set hibernate by pressing the power button my system auto startup after hibernate!!
if i hibernate manually, by mouse, no probs.
could be a current problem in the m2-atx switch? (i have tried with another one, but nothing)
PLEASE HELP ME
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
in this case the pc after hibernate go to resume automatically... than after 45 sec. m2 atx goes to hardoff and than the system stops.Originally Posted by nkotch
Your system knows to shut down but your M2-ATX doesn't. After your motherboard turns off, your M2-ATX is still providing power and so the motherboard turns itself on. If your ignition signal goes low (car is turned off) then the M2-ATX sends the shutdown signal to the mobo and both turn off together. Even if you did get the motherboard to stay off (like when you use the mouse to hibernate) then I suspect that, after the ignition goes low, your M2-ATX will send the shutdown signal to the mobo and it will actually turn back on.
and how do you fix this...
I have an Intel deskboard D865PERL that regardless of which I use, Suspend or Hibernate, it turns back on exactly 2 minutes after power down. It doesn't matter how I go to hibernation... I have tried updating the BIOS with no effect. Its the same with any version of Intel drivers and or setting to S1 or S3 on any clean install of windoze xp.
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 510MB RAM
Page File: 298MB used, 949MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
Power was OEM with current mobo (D865PERL) and case. Only changes from OEM was adition of new hard drives, but this power issue has always been the same.
Card name 2: RADEON 9250
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9250 AGP (0x5960)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5960&SUBSYS_0260174B&REV_01
Display Memory: 128.0 MB
Current Mode: 848 x 480 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6614 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 5/3/2006 08:51:00, 258048 bytes
Mini VDD: ati2mtag.sys
Mini VDD Date: 5/3/2006 08:50:42, 1540608 bytes
Card name 1: RADEON 9250 - Secondary (Omega 3.8.360)
Manufacturer: ATI Technologies Inc. (Omega 3.8.360)
Chip type: RADEON 9250 Secondary AGP (0x5940)
Device Key: Enum\PCI\VEN_1002&DEV_5940&SUBSYS_0261174B&REV_01
Current Mode: 1360 x 768 (32 bit) (60Hz)
W98 Keyboard with power, sleep and wake up keys. (Power keys do not turn on system)
Two mice, one wireless Microsoft mouse and one hard wired.
Who the heck came up with twisted emoticon..?.. LOL >>![]()
