Results 1 to 5 of 5
Thread: How much can a 150Watt Opus handle
    Apr 2006
    I want to put in an ATX motherboard, either Celeron D or AMD XP 2800+ processor, 512Mb Ram, 40Gb 3.5" Internal Hard Drive, DVD Rom Drive, SB X-Fi Soundcard, 80Gb External Hard Drive via USB, Wireless Card, GPS Antenna via USB and Wireless Keyboard mouse. Can the 150 Watt Power Supply handle it?
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    Yeah, you need a DSATX. Even then, you'll need to be a little conservative. The Celeraon D, if I am not mistaken, uses the Prescott core, which is known for its high power use and heat--it's probably not the best choice for car use. You also haven't factored in a video card, which you'll need if you're using an ATX mobo.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    The 150 Opus can handle 150 watts.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Mar 2006
    Colorado, but Canadian!
    Use a power calculator available online and select what you think you will be using. Give you a good idea of what to expect.
    I have to agree with Legarcondemerde, a prescott core will blow your car up. I never thought I would say this, but I think a Celeron is way to powerful for this application. That just felt dirty... AMD's are better with heat and power usage. A P3 system is all you really need. If you end up going the Celeron D or P4 route, you need a DSATX. Greater than that and you have an inverter.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Have a look here for info on PSU's and links to calculators. link
  1. Opus 150watt 14 gauge wire.
    By Jcarere in forum Power Supplies
    Last Post: 11-03-2005, 08:00 PM
  2. Opus 150Watt & P4 connector
    By Jaz in forum Power Supplies
    Last Post: 07-19-2005, 06:53 AM
  3. FS: Brand new opus 150watt $175 free shipping
    By jaypatel in forum Classified Archive
    Last Post: 01-20-2005, 05:28 PM
  4. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 03:16 AM
  5. FS: OPUS DC-DC 150watt powersupply NEW
    By Archangel in forum Classified Archive
    Last Post: 03-31-2004, 05:39 PM
