Results 1 to 5 of 5
Thread: Opus 150 Turns off and on every 5 seconds
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    Well ok.. we're at it again.. my car PC has been turned off completely and collecting dust for the past 2 weeks in my car
    when I first installed it it was doing this and then it was working perfectly for a week. Now ever since then it's been doing the following:
    I turn the car on, and the Opus powers everything and immediately turns it off.. then exactly 5 seconds later it does the same thing. The power surge is no longer than a second and just shuts off right after.
    I've checked ALL my cables and connections for loose things and everything is fine. This leaves me with one suspect.. the PSU... What might be doing that? It can't be TOO much stuff hooked on it because I even tried running JUST my PC and Screen and still the same thing happens..
    any ideas?
    -Emo
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    This might be the problem.
    FAQ: How to fix your OPUS 150W
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    You know, the funny thing is that I've read that thread before.. yet I'm still asking like a n00b.. haha damn
    well I'll try that tomorrow.. it'll be a ***** taking off the PSU from the place I have it now but I hope this fixes it..
    Thanks a lot Quattro! I'll post tomorrow a follow up
    -Emo
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    well as much as I hoped this was the reason it did not solve anything
    when I opened the case up, the Green LEDs blinked 3 times and stop for 5 seconds. After I did the mod where I put the electrical tape, the LEDs now blink every other second and that got me happy at first because I thought it was fixed but it does the same thing.. 5 seconds off and half a second turn on and off...
    I'm really out of ideas here...
    -Emo
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    I have had that happen with mine when the battery was on its way out. The Opus boots over and over because it gets the power signal to turn on, and then it realizes that the voltage is low, so it turns off. Try checking the voltage of your power wire at the Opus with a meter.
  1. Off - On - Momentary Switch?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 07-08-2003, 12:07 AM
