Try the power on connector the other way round.
My Opus was fully working then recently it stopped and on unplugging it and plugging it back in it has a strange problem.
Now when I plug in the power to it (Ignition is 0) the fans on the mobo come on and power is provided to the molex connectors. The ready light has 1 flash saying status is normal. When the ignition is turned on nothing happens, the LED continues to flash once and the motherboard does not start up. If you take off the power switch connector then turn on the ignition it gives the 2 flashes you would expect so it must be handshaking with the board or whatever it does.
Anyone seen this problem or got any idea how to fix it?
Turning the power cable round causes the 2 flash error.
What worries me is that it powers the molex connectors and fans when no power is supposed to be supplied to the board at all! Standby power jumper is off.
Contact OPUS... They may have a solution or issue an RMA #.
TruckinMP3
Read the FAQ!
