Results 1 to 10 of 10
Thread: Power problems... maybe?
    Apr 2006
    I've been reading these forums for a couple years now and have slowly been building my system. I've got everything the way I want it and it works great. However, lately I have been having problems with the computer just completely dying.
    I am using a power inverter which kinda sucks, but when I first started I couldn't afford a DC-DC power supply. When the computer dies I have to unplug the power inverter and plug it back in for any thing to turn on again.
    The problem is I don't know if my power invterter is overloaded, over heating, or if its about dead. Or, is it not the power inverter but the alternator being milked for all its worth and it just can't handle it? It tends to do it more in the heat of the day so I would tend to lean towards the power inverter over heating, but it does do it some during the colder months. Everything is in the cabin of the car so it's not exposed to the extreme temperatures when it is in use.
    What do you guys think?
    Variable Bitrate madkad's Avatar
    Jul 2005
    uk
    Why dont you plug it into the mains and see if the pc is the problem?
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Quote Originally Posted by howardtopher
    I think we need more information. What's the system specs?
    -psyrex
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Apr 2006
    Quote Originally Posted by psyrex
    -psyrex
    well i updated my signature with the system specs. i have had the entire system running with the thing cranked up so loud that you couldnt hear yourself talk and i havent had problems with it shutting off. you think DC-DC would be the way to go? ive been wanting to do that for a while and my budget isnt so tight anymore so it would be possible.
    computer:
    1.3GHz Celeron, 256MB, DVD
    monitor:
    Lilliput 7"
    gps:
    iGuidance, USGlobalSat BU-353 Receiver
    sound:
    Pioneer DEH-P3600, MTX 4-channel 720W amp, MTX mono 800W amp, 2 - 10" Alpine Type R subs, Alpine speakers all around
    Apr 2006
    Another question that maybe will help solve this problem.
    When I first installed and was testing, I tried to use the cigarette lighter and the inverter would sounds its alarm and not power up. So, I knew that was a bad idea right away. Now I have a ligher-like plug that I wired in myself and it goes directly to the battery. Should that be run directly to the alternator instead? My system runs fine when its not too hot, but as the temp gets warmer outside is when i start to have problems.
    Quote Originally Posted by madkad
    I have tried plugging the computer into the house and running everything and it works beautifully. I know its either the alternator or the inverter. The inverter is aging, but then again so is the alternator. I've tried to figure this out and its got me stumped.
    You guys think an 150watt opus would run this? Ive been using psu calculators and things and I'm not thinking its going to work, but maybe I'm messing up somewhere?
    computer:
    monitor:
    Lilliput 7"
    gps:
    sound:
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    This is a bit of information that is important.
    How are the components cased?
    Do you have good air flow to the: inverter, RAM, HD, and CPU?
    Some or all of your issues are heat related. This is very common.
    TruckinMP3
    Read the FAQ!
    Apr 2006
    Quote Originally Posted by TruckinMP3
    The PC is sitting in the floor board of the back seat and the power inverter is under the drivers seat. I'm pretty confident about the air flow through the case of the PC, but maybe its not sufficient. I've always suspected the inverter as I used to keep it under the hood and it hardly ever worked and moving it to the interior of the car helped out massively. I will pull the PC out and try playing with things to see if I can get the airflow any better in there.
    computer:
    monitor:
    Lilliput 7"
    gps:
    sound:
    Jun 2002
    Colorado
    Sounds like the right place to start. You may find more than one issue.
    I would recommend starting with better cooling for the inverter.
    Under the seat with a good fan is pobably ok, or out in the open for awhile to test it as the primary suspect.
    TruckinMP3
    Read the FAQ!
    Constant Bitrate Specimen's Avatar
    Jul 2005
    Los Angeles, CA
    I doubt it’s your alternator. If it was your alternator, your car wouldn't be able to run at all while you are driving. When it does die does it work after unplugging the computer from the inverter, or do you have to unplug the inverter from the battery? My guess from what you have told us is that the inverter is overheating and is turning itself off through an internal switch that monitors overheating. These regulators will then reset themselves after removing power for a few seconds like you have been doing. But motherboards and
    Power supplies also have this feature so it could be your computer is shutting its self off also.
    I would junk the inverter and get a DC-DC. DC-DC are more efficient and you’re not wasting so much power converting from DC-AC then AC-DC.
    PROGRESS [==========-] 99.9% <- Are we ever really actually done with our carPCs?
    Jun 2002
    Colorado
    Quote Originally Posted by Specimen
    SNIP
    That conversion generates heat in the inverter case....
    TruckinMP3
    Read the FAQ!
  1. Low power alarm, kind of
    By System-f in forum Power Supplies
    Last Post: 03-11-2005, 01:48 PM
  2. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  3. power up problems...
    By kingnasty in forum Newbie
    Last Post: 11-12-2004, 10:07 PM
  4. Power Problems Please Look
    By kmfdmk in forum General Hardware Discussion
    Last Post: 02-15-2004, 09:39 PM
  5. HELP!!! Need advice - power problems...
    By mwinkler in forum General Hardware Discussion
    Last Post: 02-23-2001, 07:54 AM
