does it have a cd in and have you got the bios to check for the usb on load etc etc
I had a problem that my PC would freeze right at the memory check stage (before it even starts booting the OS).
After several troubleshooting efforts I unplugged the DVD and immediately the machine unfroze and booted normally.
My question is, could this be caused by too much power being drawn from USB as I have several devices (GPS, wifi, bluetooth, keyboard, mouse) all drawing power from the USB ports and the DVD is doing so too.
If I power the DVD externally (direct from the car) will it solve the problem?
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Bluetooth, 802.11g, GPS
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
NLited XP with Road Runner and MapMonkey
[B]Car Computer 98%[|||||||||-]
Install Plan 100%[||||||||||]
Styling 20%[||--------]
Install 0%[----------]
It had a DVD movie in which I took out but it still caused the issue. I haven't checked the BIOS setting but it was working for months and I haven't changed anything in the BIOS since then.
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
bump
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Originally Posted by Tim Lake
Most likely not. Mine did that randomly. Sometimes it was good for a week, sometimes it happened 5 times a day. Sometimes it would freeze at the BIOS, sometimes it would freeze at about half through resuming XP. I ended up putting a switch on the power line so I could cut power to the DVD without having to unplug it.
I had an external 2 amp 6v regulator for it too, and it still did it. It was rock solid once you got into Windows though...
I ended up getting sick of it, and switched to firewire. Haven't had a problem since. And i got to ditch the 6v regulator, as the firewire port powers it just fine. Luckily both my VIA board, and external enclosure had firewire ports, does yours?
-ZtH01
Yes it does. Perhaps that's the way to go then. How can I find out if the DVD is compatible (I bought it off ebay and it was just taken out of a dud machine so not too much documentation!)
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
It has more to do with your external case than the drive.The drive just has an IDE to usb/firewire adapter. So, if you do have firewire you should be fine.Originally Posted by Tim Lake
If the enclosure has firewire, and your motherboard has firewire, use firewire. And get your cables from Ebay... Local places wanted like $35-40 for a 15' 6pin to 6pin. Got one off of Ebay for $8 out the door...
-ZtH01
My external USB drives was also causing my system to hang during boot and waking from hibernation. i found out that it wasnt the USB, it was becuase the drive was mounted vertically. I have a slot loading slim dvd drive, and apparently it doesnt like being mounted vertically. After I unplugged it, it works fine.
Civiputer: Dont have one anymore, but here is what is used to be!
Wierd. So it works fine if it was horizontal? Mine's always been mounted horizontally, so I know that wasn't it.Originally Posted by nameeri
-ZtH01
