I would suspect the MB.
Do you 'know' the other PS is good? If so, check all the connections, re-seat the RAM and try the desktop PS again.
Still no luck it would seem to be the MB.
I tested my m2-atx w/M2 10000 mobo inside and the cpu fan turned on but the mobo did not post. I then tried a regular atx psu and it did the same thing. im guessing that it is my mobo or maybe something is not hooked up right. Its a 500w power supply that i tried this with. Should i plug it in the car and try that to or is that a waste of time?
I bought this item as a package deal from solarpc.com. If the mobo or psu is bad can i still get a new one. i do not have any papers for either the mobo or psu? Thanks in advance for your help.
05 Str8 Black XB
Check out my project so far!!
http://www.mp3car.com/vbulletin/worklogs/61194-05-str8-black-xb.html
Check out some other picks of my car!!
http://www.cardomain.com/ride/751014
TruckinMP3
Read the FAQ!
i had the same thing happen to me after my m2 blew the 5 volt rail. so i thought it was the motherboard i had, i bought a new motherboard, got a new m2, hooked everything back up and....still no post, but the good news, the fans still spun!Anyway, i just got so fed up with it i started new with a laptop...if anyone knows what could be doing this let me know too.
