Results 1 to 10 of 12
Thread: Can I bench test my carpc using a battery charger?
    Constant Bitrate jac1502's Avatar
    Jan 2006
    My battery charger is adjustable either 2 or 6 amps. I have the opus 150 watt power supply and currently I am using a standard power supply as I get everything installed. Before I mounted the pc in my car I wanted to test it using the battery charger. Anyone see and issue with this?
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by jac1502
    Ya. It is not meant for that.
    2-6 amps MIGHT be enough. Why not just get another ATX supply and use that? THey are pretty cheap these days.
    Michael
    Jan 2006
    So i guess that is not a good idea? I would think it would be no worse than a car cranking and alternator spikes, but not sure
    Jan 2006
    I have one and built and loaded the system using it i just wanted to be sure the opus will give me all the power i need with no issues before i put it in the car
    Elsewhere
    Considering the Opus only outputs 5A, it should work fine
    How about the Wiki?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Use can use an ATX PS to power the Opus to make sure it will run your carputer. I am looking for a link that describes it.
    Michael
    Here are some
    http://www.dslreports.com/faq/9208
    http://forums.techpowerup.com/showthread.php?t=25
    You then just cut off one of the molex HD connectors, and use the Yellow for 12 volts ( I think it is yellow is 12 volts, and red is 5, but I could be mixed up on that one), and Black for ground. Doesn't matter which black.
    There you go, a ps for your DC-DC PS to test indoors.
    Michael
    Jan 2006
    I would assume it would just be
    opus ATX
    12v >12V yellow (maybe off the a drive power connection?)
    ign > 12V yellow
    ground > ground
    Jan 2006
    you beat me typing thanks!
    Falls Church, VA
    That and a small battery would work great
  1. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 11:10 AM
  2. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  3. Solar Battery Charger
    By Jcarere in forum General MP3Car Discussion
    Last Post: 12-11-2005, 12:04 AM
  4. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
