Results 1 to 9 of 9
Thread: Weird inverter problem
    Jul 2004
    Unhappy Weird inverter problem
    Bought myself an 150W inverter last week.
    But when I connect a ATX-power supply to it, it begins to tick like an relay is beeing operated and no ouput voltage. It works fine with lamps, glue-gun ....
    This happens regardless if the atx supply is 70w - 350w.
    But on one of my supply's, a 150W one. It ticks for 5-10sec and then turn on.
    Anybody knows anything about my problem?
    BTW, this happens regardless if the ATX supply is connected when I switch on the inverter or if I connect it afterwards.
    Jul 2004
    Done some more testing now.
    Opened my inverter and it is the beep'er that's making the ticking sound. The beep'er only gets power in 1 nano sec or something so it just tick's instead of beep.
    I also tried my brand new 350w atx supply and this works. I hear 1 tick before the inverter gives power but that way better than the old atx supplys I've tried so far. But now my inverter(yes, my inverter and not my atx supply ) makes this buzzing sound.
    Is there a way around this?
    Newbie didiet78's Avatar
    May 2006
    Bandung, Indonesia
    Buy another inverter ?
    Just curius, that inverter square wave, modified square or pure sine wave?
    Jul 2004
    Quote Originally Posted by didiet78
    No, the next thing now is an DC-DC supply!
    It stands "Modified sine wave" on the back of it.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    That 150w inverter isn't really good for much, maybe a small laptop.
    Try getting something bigger if you stay the inverter route.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    the noise is due to the inverter being overloaded. You need to use an inverter rated about 25-30% higher than your PSUs rating. Even if you are drawing that much it just does not work right in some situations.
    May 2006
    Bandung, Indonesia
    Quote Originally Posted by zanor
    You need more wattage inverter or u need to limit inrush current your ATX power supply.
    Variable Bitrate numbers's Avatar
    May 2005
    Cut the ground prong off the power cable. It might not help, but you don't really have anything to lose in trying.
    Jul 2004
    Thanks for all your replays!
    But never mind, just ordered an M2-ATX
    And btw "numbers", there is no connection to the ground in the outlet of my inverter.. Thanks anyway
  1. weird problem with MapMonkey
    By rasheedn in forum Map Monkey
    Last Post: 02-26-2006, 06:00 PM
  2. Weird Iguidance Problem 2.1
    By megadivers in forum GPS
    Last Post: 08-24-2005, 01:44 PM
  3. Replies: 6
    Last Post: 08-19-2005, 12:23 AM
  4. weird sound problem
    By jermaine in forum General Hardware Discussion
    Last Post: 06-04-2005, 03:11 AM
  5. another inverter problem
    By dizzzyduck in forum General Hardware Discussion
    Last Post: 07-18-2000, 10:55 AM
