Without knowing what you setup is that's an imposible question to answer, for some reason I can't seem to see your sig. If it is a simple setup you should be OK, just but without putting a powermeter, and see just how much electrisity your using it's not possible to say for sure.
Personally I don't like inverters but if I was to use one, I'd go for the 140 watt over the 50 watt, that way there is room for expansion in the future.
Rob
LinkBack URL
About LinkBacks
(Statpower's had problems with the extreemes of chicago winters).
