OK. You don't use the brick at all. you cut the cable between the brick and your battery...
you make the following connections from that wire...
BLACK wire - Ground this one
WHITE wire - Ground this one
YELLOW wire - tape it up - don't use it.
GREEN wire - tape it up - don't use it.
RED wire - connect this through a fuse to your battery
BROWN wire - connect to the same place as the RED wire
to tell you the truth, you don't need to connect the white or brown wires to anything, just tape them off so that they don't short against anything...
You will not use your brick in the car...
AS for the boot up, I would suggest installing a fresh copy of windows. if you have alot of programs running on it, i will take a while to boot. Mine boots in about 35 seconds or so from the time I stop cranking the engine...
LinkBack URL
About LinkBacks
And CdRskull... Love your
