Results 1 to 10 of 15
Thread: Remotely turn on computer (not necessarily car)
    May 2006
    Hello everyone,
    I am currently considering having a cellular controlled carputer/car alarm. The basic idea is a car alarm, integrated with a computer, which in turn is plugged into the phone.
    The idea here is to be able to remotely control your car alarm with a cell phone.
    My idea on the process flow is as follows. User with cell phone sends particular text message to a second phone that's in the car, this phone turns on the computer, which in turn activates the car alarm/makes setting changes etc.
    I have a Nokia 6620 cell phone with USB data cable and it runs a Symbian OS so i was hoping that in order to turn on the computer, i simply program it to send a wake-on-usb signal to the computer, which turns on. Either from a full off state, or an S3 sleep state. However, the problem I ran into is that the USB interface that's implemented with the Nokia phone uses a proprietary technology called PopPort for which no API has been released, i am unable to send this signal.
    So now the question is this, what other way would there be to turn this computer on? The phone, other than the popport, also has an IR module, which i could technically put close to an IR receiver if there are any IR receivers capable of turning a computer on.
    I didn't know where to put this question but i figured the power supply forum would have some interesting insights into how i can turn a computer on creatively.
    Any help would be appreciated,
    Thanks.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Sounds like you'll need another computer, or maybe something with a Parallax STAMP chip that you can program to do something with the IR codes.
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    you want to consider a completely electrical circuit solution ... requires hacking the cell phone. When you dial the cell phone, the lights come on or the speaker is activated to ring. You could probably wire up a relay which is connected to the cell phone speaker / lights -> relay-> the momentary switch of a computer button.
    Hope this makes some sense ...
    [ 5-spd 1996 M A X i M A SE ]
    Newbie didiet78's Avatar
    May 2006
    Bandung, Indonesia
    Or you can send any command to IR. Just search IR activated switch and that will do (maybe )
    Newbie yellowjeeperman's Avatar
    Mar 2006
    Oakland County, Michigan
    How bout something like this....
    http://www.thinkgeek.com/pcmods/cases/8095/
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    there was a post on here somewhere a little while ago about someone with an alarm service that you could call in to start your car, i imagine you could set up an auxilary.
    Jul 2005
    Tampa
    Remote Start.
    For the Car -- I have a DC-DC power supply, with a trigger hooked to one of my 'keyed' circuits, the radio. So when I turn the key, since my radio I leave always on, the computer boots. Simple concept, but last year I bought a remote start kit for about $40 at Kmart of all places, and after some trial and error got it to work. Now, since it's still tied to the radio, 'always-on', I can warm the car, in the winter, cool it down in the summer, and not sit through the post screen before I get in my car. Something to think about, the cell-phone thing sounds cool though, keep us posted.
    Mar 2006
    Colorado, but Canadian!
    Audiovox CL-100 is a satellite paging system. Lifetime activation with purchase so no monthly fees. It has a data output that hooks into Audiovox alarms, but you could build a simple circuit that interprets the data it sends (like start car, lock/unlock doors, arm/disarm alarm) and change them to things like start/shutdown computer and things.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    San Diego, CA
    I think you could use a DC-DC power supply like the CarNetix P1900. It has a remote pulse input that will send the ACPI signal to the motherboard. You can use a switch or a pulse (like when your parking lights flash with your alarm turning off). That way when you unlock the doors, the parking lights flash and the signal is sent to turn on the unit.
    I just read the manual for the P1900, loads of options for remote start, shutdown control, etc. Check it out... http://www.carnetix.com/installation...ManualV2_0.pdf
    ~Puff
    View my worklog... I dare you... http://www.mp3car.com/vbulletin/worklogs/77267-2003-audi-a4-worklog-puffs-ride.html
    Carputer Progress [||------------------] 10%
    Newbie Mark0055's Avatar
    Jun 2006
    Fleetwood, England
    I've been wondering exactly this myself, because if you could wake the pc from the phone, (and then get the pc to use that phone for a data connection) you could ask the computer where it is! (pc would use the usb gps you bought for sat nav)
    Therefore youve got satelite tracking without those tedious subscription fees!
    you could also get the PC to take pictures of the F*****er thats stolen your car, put you in voice contact with him , cut the engine, lock the doors , deploy the teargas etc etc
    But from the above posts it seems theres no obvious easy solution. all the suggestions come down to getting a signal out of the phone to feed into the pc
    If this was a normal pc at home I'm pretty sure BIOS's have "wake on modem" which would solve the problem, but if its a cellphone being used as a modem i cant see it working really without (as i think someone said) physically hacking the phone and getting voltage from the phones speaker or light and connecting it to .. well .. the wake on lan line that goes from nic to motherboard?
    actually operating a relay that just presses the power on button would be simpler , like the SDCs do , some probly have an input for just this. infact the main input from the ignition key is just that
    hmm - light at the end of the tunnel
  1. Computer doesn't automatically turn off
    By Teranfirbt in forum General Hardware Discussion
    Last Post: 09-25-2006, 04:44 PM
  2. *almost* Completed Car computer
    By XxAndyxX in forum Show off your project
    Last Post: 11-24-2005, 02:33 PM
  3. Troubleshooters! Computer turns off randomly and wont turn on, need help
    By phatbimmer in forum General MP3Car Discussion
    Last Post: 06-05-2005, 06:09 PM
  4. Keep computer on while powering car
    By phatchink in forum Power Supplies
    Last Post: 03-06-2005, 09:34 PM
  5. Power problems with car computer :(
    By Bitflip in forum General Hardware Discussion
    Last Post: 04-26-2004, 04:13 PM
