Results 1 to 8 of 8
Thread: A newbie inverter question
    Mar 2002
    Long Island, NY
    Question A newbie inverter question
    I bought a SIMA inverter that says its output is 120V and max 200V. I thought this would be sufficient for my carputer, but when I plugged her in, after 10 secs the inverter shuts down and the overload light goes on.
    I am using my sister's old DELL 200 MHZ MMX computer, and on the back it says:
    Volts: 115/230 ~
    I didn't ground the chassis and I had to use a 3 to 2 prong converter, because the input on the inverter is 2 prong. Do I need to buy a higher wattage inverter or do I need to do something different?
    Thanks alot, go easy on me =)
    Grand AMplifier Project 1.0:
    http://drive.to/cliffsgrandamgt/
    http://www.astallaslions.com/carmp3/
    -Eden 800 mini-itx motherboard
    -5.6 NTSC TFT-LCD
    -80 gig hard drive
    -128 MB RAM
    -MPBS1 DC-DC PSU
    -PB Remote /w Girder
    -Media Engine & Windows XP
    -Playstation II also added
    -Steering Wheel Buttons modified for Control.
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    what is the power rating on the inverter?
    if it is an ac inverter it will always be 120 v. but what about amps/watts? i cant remember which they are rated in.. i'm pretty sure it's watts...
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Mar 2002
    Long Island, NY
    the rating is 140 watts but like I said it said min. 120 and max 200
    -5.6 NTSC TFT-LCD
    -80 gig hard drive
    -128 MB RAM
    -MPBS1 DC-DC PSU
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    volts and watts are completely different things, altho they both have to do with electricity. 115VAC is US voltage, 220VAC is Europe. The power supply is probably 150 watt psu (might say on the sticker on it). Your 150W psu is most certainly overloading your 140W inverter at power on.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Mar 2002
    Long Island, NY
    Lightbulb
    would you say something like this would remedy the problem? =)
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1342679098
    It says in the description that the voltage out is 110V...the back of the DELL says 115V...but this seems to be the popular choice on the board..
    -5.6 NTSC TFT-LCD
    -80 gig hard drive
    -128 MB RAM
    -MPBS1 DC-DC PSU
    Jan 2002
    Chicagoland, IL
    Yes, that would remedy the problem. 110~120 volts ac is standard US wall current (ac=alternating current). I've used the jensen for a period of time, worked well enough (was a bit loud when cold).
    -Nick
    Apr 2001
    Chicago Suburbs
    cliff.... buddy....
    forget about voltages for a second
    as long as you have an AC computer suppy and an AC inverter... you are going to be fine.
    the thing to look at is the watts. 300 watts is more than enough to power a computer as powreful as a p4. so that inverter should do the job.
    ~Mike
    Mar 2002
    Long Island, NY
    Originally posted by mp3z24
    cliff.... buddy....
    ~Mike
    Ok thanks alot! You mean the 300W one by saying "that inverter" right? Cause the 140W wasn't enough.
    -5.6 NTSC TFT-LCD
    -80 gig hard drive
    -128 MB RAM
    -MPBS1 DC-DC PSU
