Results 1 to 2 of 2
Thread: Installation problems
    Mar 2006
    Sweden
    Hi!
    Many of us have problems during the installation of the computer in the car.
    So, what is the best thing to do in order so solve these problems?
    Check the cables with a voltmeter or what is the best thing to do first?
    I´ve just installed my system and its all dead. Will problably check the cables tomorrow so that there is enought power to my opus.
    // I
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    first check the wires with the volt meter. make sure you have 12v on the power and acc lead (when the key is in the 'on' position) check your ground using the resistance setting on the voltmeter. you should have 0 ohms for resistance. try hooking up the computer to an regular computer psu that you plug into the wall outlet, make sure that the computer is working and not the problem. if all those things check out, then it may be a problem with your power supply.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 05:17 PM
  2. Problems with new version 1.5.0
    By lucianop in forum PhoCo Bugs
    Last Post: 10-18-2005, 03:15 AM
  3. Still having XMPCR problems
    By rjoek in forum RR Bug Tracker
    Last Post: 09-23-2005, 01:08 PM
  4. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 08:40 PM
  5. Replies: 2
    Last Post: 08-23-2005, 06:11 AM
