Results 1 to 8 of 8
Thread: HELP, image flickers when music is playing!!!
    VMS
    VMS is offline
    Low Bitrate VMS's Avatar
    Apr 2006
    The image flickers when music is playing. I know its not the LCD because when i power the computer using AC DC inverter, this doesn't happen. I've got the inverter hooked to the car battery which is a very small unit. Does any one have any segestions on how to fix the problem. I'm guess i should regulate the 12V DC source but how do i do this? Would a better battery solve this problem?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    hi, this is noise from the computer/harddisk/etc all affecting the lcd's powersource.
    ur right in assuming you should regulate the supply. perhaps something like a compressor on the line to the psu would help. I reduced my problme by doing so, but it's still there. the next step I'll take is to use a secondary dc-dc powersupply to power the screen + peripherals.
    VMS
    VMS is offline
    Apr 2006
    I'm not powering the LCD from the PSU, the LCD is powered from the origianal power provided for the origial CD player. The computer is in the boot. Would grounding the case help? Also, what is a compressor and where do i install it?
    VMS
    VMS is offline
    Apr 2006
    BUMP... i've tried grounding the computer and the LCD to the same spot, it ddin't help. I'm going to by a noise filter today and see how it goes.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    that's a good plan. the best way to do this would be to power ur LCD from a very celan source, like the PSU itself. (if it can handle the load)
    VMS
    VMS is offline
    Apr 2006
    The screen is a lili 701 so it has internal amps, don't think the PSU can handle this. Anyother alternatives?
    Variable Bitrate M^ck^y's Avatar
    Aug 2004
    Melbourne
    If the problem is still there... Have you noticed if it flickers more when the engine is running and a difference in flicker when you rev the engine (alternator)
    let us know. If you have fixed it already, what did you do
    Apr 2005
    Dublin, Ireland
    I had the same issue with flickering, i would power your screen from the PC PSU to ensure itss getting clean power, that should resolve your issue, it did mine.
    P4 Celeron 2.2 - 512MB - OPUS 250 - Audigy SE - BU353 - HQCT - No Speakers though :-(
  1. Music directory changes to system dir?
    By CavityCr33p in forum CF Bug Reports
    Last Post: 08-30-2005, 01:05 PM
  2. Play Music Files among Several Computers
    By Wiredwrx in forum Off Topic
    Last Post: 08-08-2005, 10:49 PM
  3. 4am MUSIC Console 1.5 (music jukebox)
    By OvernightTech in forum Software & Software Development
    Last Post: 09-01-2003, 03:10 PM
  4. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 10:08 PM
  5. Playing different types of music and video files
    By wysiwyg in forum General Hardware Discussion
    Last Post: 02-10-2003, 11:26 AM
