Results 1 to 8 of 8
Thread: M2-ATX, What's J10 D?
    Jul 2004
    Hi!
    Just ordered M2-ATX and going trough the manual now. In the section covering the timing jumpers there are 7 options, but jumper "D" is never used. Is this used for any other function?
    EDIT:
    And what happens if I turn my car back on while PC is still shutting down? Or if I turn off my car while PC is still booting?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    30 Min Off Delay, M2-ATX? post 6 for the jumper question
    Elsewhere
    Quote Originally Posted by zanor
    Shutting down while the PC is booting is bad news. You can bork Windows system files and bring about the need to repair/reload Windoze.
    Trying to power on the PC during shutdown will do nothing.
    How about the Wiki?
    Jul 2004
    Quote Originally Posted by v8 scimitar
    Thanks! That was exactly what I was hoping for!
    FLAC sama's Avatar
    Feb 2006
    London, UK
    darque, if the pc is shut down at any stage, but using a readonly CF install. does it matter in any way? I'm guessing not.
    i intend to run my carptuer this way eventually.
    Jul 2004
    Quote Originally Posted by sama
    Yes, that's my goal too! Not having too wait for the system to shut down every time
    I had HORM running on my harddrive just to have fast shut down time, but I turned it off again because I had some complications about not beeing able to write to D: either. But I'm going to do a new try when I get money too buy a 1GB CF card
    Elsewhere
    Couldn't tell you, as I'm not booting from a CF card.
    How about the Wiki?
    Jul 2004
    Anyway Darque, I don't think you understood me. Because I wasn't talking about cutting the power to my carputer while windows was booting. I was talking about turning off my engine so the M2-ATX looses it's signal on the IGN input. And then the M2-ATX want's to shut down my PC by "pushing the acpi power button" but the PC dosent get that signal because it's still booting and then if M2-ATX is set to do a HARDOFF afterlets say 45sec then that will cut the power to the PC.
    But I'm going to go for the 1hour/1hous 15min sequence that v8 scimitar pointed me too so that's not going to be a problem no more.
  1. M2 ATX Amp turn on not working
    By CdRsKuLL in forum M2-ATX
    Last Post: 04-23-2010, 12:25 PM
  2. Replies: 3
    Last Post: 01-06-2008, 03:11 PM
  3. Another M2 ATX Problem
    By mattfl in forum Power Supplies
    Last Post: 02-23-2006, 04:47 PM
  4. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 01:14 PM
  5. Wtb: M2 Atx
    By EsKALad in forum Classified Archive
    Last Post: 01-03-2006, 08:59 AM
