Results 1 to 3 of 3
Thread: did i fry my m1-atx? can i use another PS to test the mobo?
    Constant Bitrate megagoo's Avatar
    Oct 2004
    i was in the process of moving my carpc from the front to the trunk area. it powered up fine initially during the move in one of my tests to make sure..
    there are two wires coming from my LCD that run to the power supply. i plugged them in backwards at firsts. saw the monitor wasnt coming on. plugged them in correctly. then i notced the computer wasnt powering on when earlier in the day it was.. i put a volt meter on the m1-atx pins .. most of the pins show only a couple millivolts. the "5V_SB" shows 5v and the 12v pin right below that shows 5v.. but most of the rest of the pins show nothing.. is this a dead m1-atx? my guess is yes
    oh and when i give the pc power, only the processor fan spins. but i have to kind of help it along to get started spinning...
    second question is can i get a friends 300 watt power supply and use it in place of the 90 watt m1-atx just for testing purposes, or is this too much for the motherboard (epia m-10000). im not sure if more wattage can fry a motherboard
    kind of sucks.. the only thing i can think that could have done it was plugging in the lcd power wires backwards
    any help is appreciated
    thanks
    eddie
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by megagoo
    thanks
    eddie
    Wattage can't harm anything, only voltage can.
    Michael
    Oct 2004
    ok well i plugged an extra power supply in and everything works perfect. the only question left is how did i blow the m1-atx?
    could simply swapping hot and ground wires coming from the m1-atx to the LCD fry the thing? hopefully my monitor is ok. christ i hate when this happens
  1. $200 DC-DC ATX PSU + CASE + MOBO + C3 800mhz CPU
    By moahdib in forum Power Supplies
    Last Post: 05-20-2002, 09:50 AM
  2. Replies: 2
    Last Post: 04-28-2002, 11:59 PM
  3. Replies: 3
    Last Post: 01-29-2002, 11:12 PM
  4. Arise PS with atx mobo? ----)>
    By BeigeMaxima in forum Power Supplies
    Last Post: 07-26-2001, 10:28 AM
  5. ATX mobo users how did you hook up power on switch?
    By BeigeMaxima in forum General Hardware Discussion
    Last Post: 06-25-2001, 09:00 PM
