Results 1 to 2 of 2
Thread: Need Wiring Help ASAP THANKS!
    May 2006
    i'm using this switch to ground my avelectronics nav lite unit (for testing purposes of course)
    I dont' understand where the resistor goes and how the led light is going to get power.
    anyone with good wiring skills help me out?
    1. I run the ground wire into the input.
    2. I have another wire coming out of the output. This switches the ground on or off therefore switching the unit either on or off.
    Then what?
    I understand what a resistor does, but how does the led get power? Like Do I bring a +12 v in here somewhere, then hoook it up to the resistor then the resistor to the led power? also how does the led ground get grounded? what is the jumper wire thingy?
    Help. I need to install this asap. Thanks!
    May 2006
    anyone?
  1. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  2. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  3. Wiring Xenarc to wiring harness?
    By deftones8769 in forum Power Supplies
    Last Post: 04-10-2005, 10:07 AM
  4. LCD wiring? Help needed ASAP!
    By DrSergioDJ in forum LCD/Display
    Last Post: 02-06-2004, 02:28 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
