Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Powering car from a 13.8V power supply ok?
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    For a ham radio my grandpa gave me an old power supply he found at a flea market or something, it says it is an astron rs-20M (http://www.labx.com/v2/spiderdealer2...m?LVid=3058432) and puts out 13.8 volts DC at 500 watts, and has a 5 AMP fuse.
    I (will) have a m2-atx power supply powering my compy in the car soon, and I was wondering if I tied this into the car if I could power the computer for extended periods off of house power rather than off of the car battery. Will it dammage anything? I would imagine it would just charge the car battery and power everything, but I am no expert at these kind of things.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
    Maximum Bitrate Zebelkhan's Avatar
    Dec 2004
    Bay Area, CA
    M2 will take from 6v to 24v so that is not a problem. However it would not be advisable to do that unless you find a way to cutoff the car battery after it has reached full charge. Overcharging your car battery will damage it. It is better if you install a simple switch (or relay) so when the power supply is plugged in, M2 will feed off of the supply and revert back to the car battery when it is unplugged.
    Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    13.8 volts shouldn't overcharge your car battery. The great thing about lead-acid batteries is that when you apply a charging voltage of 13.8 to 14.4 volts, the battery only accepts a charge until it is full, then it just "floats" and draws next to no current.
    Dec 2003
    Germany
    I second that. Just think about what your alternator would do to your car's battery on a long drive
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
    Mar 2006
    Colorado, but Canadian!
    Question
    Quote Originally Posted by BassBinDevil
    Then why the hell would anyone buy a trickle charger with a "smart" circuit to stop sending current? Is this really true?
    Dec 2004
    Bay Area, CA
    On a long drive alternator does not damage the battery because it will cut power to the battery once it senses that its draw has been reduced. As far as the battery is concerned, because of the open cells in most lead-acid batteries, overcharging will tend to generate excessive oxygen and hydrogen gas reucing level of electrolyte running the risk of exposing the electrodes and causing degradation, which will permanently damage the battery.
    Here is also an excerpt from the following site:
    http://www.bigginhill.co.uk/batteries.htm
    "A reasonable rule of thumb is that you should aim to charge the batteries only when they are between 70% and 40% discharged. If you charge them then they are only lightly discharged i.e. less than 40% you will end up boiling them unnecessarily which wastes energy in the form of heat and gassed off hydrogen and in turn shortens the life of the batteries. In effect the batteries are being overcharged which can cause degradation and buckling of the plates. In the process some active material is forced off the plates and drops down to the bottom of the battery. If this occurs frequently the eventual result is a build up of a bridge between the plates which in turn can cause a possible short across the plates. This situation leads to the destruction of a cell which then reduces the capacity of the battery."
    Apr 2006
    Quote Originally Posted by Zebelkhan
    As I know, the M2 ATX have time off, it means you can turn on after start engine.
    Frederick
    Nov 2004
    I could be wrong, but the "smart" circuit is probably just a voltage regulator. Smarter chargers have an "equalize" mode where they deliberately overcharge the battery for a limited time to make sure all cells are equally charged, but after that they revert to "float" mode, where the battery sits around 13.8 volts and doesn't accept any current. Dumber chargers are unregulated and will keep on feeding current into the battery until it's warm and bubbling or you remember to disconnect it.
    If the supply is regulated to 13.8 volts, it will not overcharge the battery. That's how your car's alternator does it. It can't tell whether the battery is drawing current (to charge itself) or that current is going to the headlights or electric seats.
    Low Bitrate S11D336B's Avatar
    Feb 2005
    Florida
    Just put a rectifier diode on the power lead running to your battery from the M2 so that the house power supply can't charge your battery.
    ________________________________________________
    Worklog
    K7VTA3
    1500+ Athlon 4 Mobile
    510mb PC3200 DDR
    ATI Radeon 7000 64mb
    [||||||||||] 95% Complete
    RentATechnow.com
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    BS... that is why float and trickle chargers are made.
    Quote Originally Posted by Jeeve5
    BS... Car charging systems use a voltage regulator to prevent damage to the battery.
    Again, BS... See above for car system.
    TruckinMP3
    Read the FAQ!
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. is 350W power supply will work in a car too ?
    By shinjetko in forum Power Supplies
    Last Post: 03-26-2006, 09:10 AM
  3. power inverter power supply shutdown problem
    By launter in forum Power Supplies
    Last Post: 09-21-2005, 12:12 PM
  4. Power problems with car computer :(
    By Bitflip in forum General Hardware Discussion
    Last Post: 04-26-2004, 04:13 PM
  5. Would this work as a power supply in the car??
    By rhinoofstockton in forum Power Supplies
    Last Post: 04-22-2004, 06:03 PM
