Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: What does DSATX solid light mean? PLEASE HELP!
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    I can't figure it out. I just swapped this with my old opus 90w with my epia m10k and the light is just solid........i tried switching the poweron cable thing to all the little pins and can't figure out what I am doing wrong.........
    PLEASE HELP=!
    Thanks !
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    OFF = System off / sleep mode
    ON = Running Mode, the computer runs/boots in this mode
    1 blinks = main countdown timer
    2 blinks = shutting down (after shutdown pulse is sent)
    3 blinks = N/A
    4 blinks = Over or Under Temperature Condition. (Are you using a fan?)
    5 blinks = Power Supply Overload or Fault. (Did you hook up way too much stuff?)
    BossTone74
    Feb 2005
    The Yay Area (SF)
    thanks so solid/no blinks is normal then? so what am I doing wrong???? my pc wont' startup
    May 2002
    Japan, Oregon
    I don't know man...I don't have that one...I just found the codes for you one this site...
    is the board powering up at all (fans spinning)?
    check your VGA connection if it is...
    BossTone74
    Feb 2005
    The Yay Area (SF)
    ok got fan working and pc light comes on, but the pc like keeps trying to start and never does......it likes starts up makes 2 clicks and then starts up again and it never stops even when the car is off............
    what does "1 blinks = main countdown timer" mean? that is what it is doing right now while the mobo tires to startup over and over
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    did you ?
    try this: reverse one just one end of the mobo power button cable.
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    Feb 2005
    The Yay Area (SF)
    yeah i searched......i'tll try that thanks.....
    JAC
    JAC is offline
    Low Bitrate JAC's Avatar
    May 2006
    North of NY
    My 90w had similar problem when I powered the system it would come on then shut down. Then I reversed the way I powered it with ground not used until last to see if I had a short somewhere and the mobo started up with no problems without using ground. I know it ain't logical but I shorted the 90w m1-atx. I not saying you should try this just maybe you have a short somewhere..
    Feb 2005
    The Yay Area (SF)
    thanks so what would i do about it if i had a short?
    JAC
    JAC is offline
    May 2006
    North of NY
    Your power supply isn't busted just trying to tell you hey somethings wrong check all your connections carefully til you find it. It helps to write it down as you go for some reason I skipped this part and had trouble tracking the next day what I had done. If you use your old 90w does the mobo start-up ok?
  1. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
  2. Replies: 22
    Last Post: 01-05-2006, 09:26 PM
  3. How many does it take
    By veedubya in forum Off Topic
    Last Post: 06-03-2005, 01:15 PM
  4. BU-303 Dim Light????
    By KingsDude in forum GPS
    Last Post: 02-12-2005, 10:23 PM
  5. High Bright Sun Light Readable LCDs
    By PORTUGAL in forum LCD/Display
    Last Post: 06-23-2004, 12:19 PM
