Results 1 to 3 of 3
Thread: Opus 2 or 3 flashes
    Apr 2005
    Vancouver
    Opus 2 or 3 flashes
    I got a problem of my Opus 90W..
    I did all the wiring and I used it for a period of time ( around few months) but recently, my opus doesn't power up the motherboard , the led flashes twice , and i check the wiring, and plugged again to the motherboard, then the led flashes three times, as i know three times flashes means that the battery is low , or output overloaded or shorted... but i recharged the battery or even connect to the battery charger, the led still got three flashes......
    what can i do for that ? should i change to use M2?
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    can you try another motherboard? also check your power switch pins. They could be reversed. Have you tried powering it up with a standard ATX PSU? Unfortunately it could be a dead PSU, if this is the case, try contacting OPUS.
    Apr 2005
    Vancouver
    yea the motherboard is bulit-in in a case which has a power supply already and it works fine as a tv multicenter for me and now i wanna put it back into my car, and i did check the switch pin when i saw the two flashes, after i changed it , it became normal one flash, and when i turned on the engine and the opus has three flashes and the motherboard fan keep moving a bit and stop continously...
    i guess my opus is dead?
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. Opus 120 and MTSVO-SC, wiring questions
    By 01black_ac in forum Power Supplies
    Last Post: 03-22-2006, 08:36 PM
  3. I hate Car PCs!! Opus Problems!!
    By Anees in forum Power Supplies
    Last Post: 12-01-2005, 09:26 PM
  4. opus flashes - pc wont turn on
    By SexualChocolate in forum Power Supplies
    Last Post: 10-22-2005, 09:35 PM
  5. OPUS 150 three flashes
    By spyda in forum Power Supplies
    Last Post: 03-22-2004, 09:27 AM
