Results 1 to 4 of 4
Thread: Powing a CD-Rom??
    Newbie tibbygt's Avatar
    May 2006
    Powing a CD-Rom??
    Hey,
    I am building my first system in my car. I have years of IT experience and have only on question that is baffling me. How do i power the external USB cd-dvd drive i am using, it has a standard power cord that plugs into the wall but i want to use this particular drive for integration purposes and its a slot load rather than a tray, very OEM looking. Any ideas??
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    WEll you just need the propper DC-DC adapter.
    The wall plug most likely is a transformer which takes the AC and turns it into (since its a USB unit) most likely 5v
    You could take the 5v from the computers psu or get another DC-DC adapter for that purpose alone.
    Note, if the original adapter outputs 12v, DO NOT connect it straight to the cars power line. It is UNREGULATED and can vary from 10 to 14 volts potentially frying the unit.
    Either get the power from the PSU (which is regulated) or other regulated DC-DC adapter.
    As for getting it to the unit. simply splice the wire from the original adapter, take the output from the DC-DC adapter and send it to the spliced wire.
    If you dont want to cut up the original piece, head over to radioshack and see if they have the same type of plug in stock and use that.
    Brown 2010
    May 2006
    your the man
    hey thanks for the info i really appreciate it
    Mar 2006
    NJ/RI
    LOl, no problem
    Brown 2010
  1. Help!
    By WRX2001 in forum PhoneControl
    Last Post: 01-25-2005, 04:50 PM
  2. Motorized LCD Display - CD ROM
    By Gauderio in forum LCD/Display
    Last Post: 06-20-2004, 02:50 AM
  3. Adapter for IBM CD ROM
    By Alphared in forum General Hardware Discussion
    Last Post: 01-06-2003, 06:25 AM
  4. good laptop cd rom ?
    By oddcomp in forum General Hardware Discussion
    Last Post: 11-14-2002, 02:54 PM
  5. CD Rom Question
    By Genesis in forum General Hardware Discussion
    Last Post: 12-29-2001, 11:42 PM
