Results 1 to 8 of 8
Thread: Powering DSATX with atx power supply problems
    m0f
    m0f is offline
    May 2006
    Hi. I just for the first time fired up my carpc on the bench last night. Everything seemed to startup and run for an indefinate time in the cmos setup. I inserted the windows cd and booted into setup. Everytime it boots up to where it would normally prompt you to hit enter and shuts down completely.
    Powering the DSATX is a Macron 350w supply with all the yellow 12+ wires together and the black ground wires togher. The grey is wired to ground as well so the supply is hardwired on.
    When the pc shuts off, the house PS fan also shuts off which leads me to believe it's going into some sort of fault protection, so that indicates it's not the dsatx but the house ps causing this issue ? It's strange as it's supposed to be able to produce 20A to the 12v rail.
    Another thing to note, if I unplug the hard drive it boots into the windows setup fine. Also also with a house PS hooked up directly it works perfectly.
    Just looking for someone more experienced to confirm my suspicions before hooking it up to a car battery.
    EDIT : Just wanted to add that it's a 51w athlon 64 3000+ 754, 512MB, 1 Samsung sata hard drive and 1 dvdrom. So it shouldn't be too much of a power hog.
    Apr 2001
    Portland OR
    Quote Originally Posted by m0f
    A. The Gray wire is the wrong wire to ground, you should be grounding the green wire.
    B. Are you meeting the minimum load requirements on the Power supply? Is the output Current 2-30 amps on the 5 volts, or is it 0-30 amps?
    C. Is the DSATX Flashing it's LED at you?
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    m0f
    m0f is offline
    May 2006
    Thanks for the reply.
    I double checked the wiring again. There is no green wire on this supply, but I check the pinout at http://xtronics.com/reference/atx_pinout.htm and it I'm pretty sure it's the correct one. 4th from the left top row when pictured like in the above url.
    I am looking at the diagram head on as if the wires are entering through the back of the diagram, which is the way everything else appeared to line up best. If this is not correct please let me know.
    Good point about the minimum load. Unfortunately it does not specify, only the max.
    The led on the dsatx is solid one while the computer is running. When it shuts off, the led immediately goes black, as well as the fan on the ac/dc power supply shuts off completely.
    Apr 2001
    Portland OR
    One thing you can try is to plug some old hard drives into the AC-DC power supply to give it a minimum load.
    www.mpegbox.com
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Most psu need a load on the 5v rail or they shut down / go into a fault mode.
    Lez, more widely known as flez1966
    Jan 2006
    t.o.
    You can get the ac-dc power supply to turn on / stay on by shorting the green wire (pin 14) with a black (pin 15) using like speaker wire or something. Then it will turn on/off using the switch at the back of the unit, without plugging any other hardware into it.
    Elsewhere
    I made a pair of cables to make hooking my DSATX up to a spare power supply inside.
    The first uses a 3-pin fan header and a bit of solder. I looped a wire around so it shorts the outer two pins of the fan header, which fit neatly into the ATX plug for pins 14 & 15. I may wire a switch to this adapter, so I can have a convenient button to press to turn the PSU on/off when I'm testing.
    The second uses a HDD cable with a 3-pin fan header off it (I had about a half-dozen of these that came with some case fans). I cut the 12v & ground wires, as well as one end of the fan header.
    The 12v, Gnd & fan header then go into the three pins of my quick disconnect (representing _12v, Gnd & ACC). There's a switch attached to the fan header that maintains an on/off state, so I can simulate turning the ignition on/off to test DSATX shutdown functionality.
    There are pics of them in my worklog, but they aren't very clear, I don't think.
    How about the Wiki?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Some/most AC PSU need load to work like other has said.
    The pin you shorted is Pin 14 and 15. Color code is not really standard, but you did correctly (grey on yours but green on others).
    If you just want to bench test hardware and software, why not plug the CD/DVD ROM to the AC PSU? But better off just use an old HD/DVD drive to give load to the AC PSU so you know that the DSATX can power all your hardware.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. DSATX Power Supply on LV-673 MoBo
    By Caelric in forum Power Supplies
    Last Post: 12-17-2007, 03:21 PM
  2. powering m13000 through atx power supply?
    By shocker1185 in forum General MP3Car Discussion
    Last Post: 12-05-2005, 05:09 PM
  3. Replies: 8
    Last Post: 08-22-2005, 11:43 PM
  4. Very Small/Mini Power ATX Power Supply?
    By xBrady in forum Power Supplies
    Last Post: 06-20-2004, 06:22 PM
  5. Easy ATX power supply queston
    By dudah85 in forum Power Supplies
    Last Post: 07-10-2001, 12:59 AM
