Results 1 to 5 of 5
Thread: Freezing and booting problems! 2nd Day of Install!
    Mar 2006
    Colorado, but Canadian!
    Hello.
    When my CarPC works, it works very nicely. Only thing is alternator whine, but my ground is like 3ft long so, have to fix that!
    I have a M10000, an M2-ATX, 1Gb RAM, and a 250Gb 3.5" drive.
    Well anyways, heres the thing. Sometimes the audio freezes. The flash logos in RR keep spinning and the title continues to scroll though. I think that it is the harddrive not getting the info fast enough because of the bumps. But sometimes it freezes completely. Usually after the A/C is turned on or something like that, so I'm thinking the power is getting screwed up and then the computer is freezing. I don't know. Never had to diagnose something like this in a car.
    So, then when it freezes, I push the power button for 3 seconds and that shuts it down. Well used to. Now it doesn't. When it is off, and I start the car, the M2 turns the mobo on, so it is connected properly. Now nothing happens when I push that button. After it freezes like that, I now have to physically disconnect the 12v constant to shut it all off. Then when it reboots I get one of two things:
    1. It says disk boot error, or
    2. the motherboard stays on and the screen is blank. Then the screen says no input and turns to power saving mode.
    I'm pretty sure the hard drive is good. Guess I'll check that later, but it worked in the house. Also when it is in the blank state like that, I can't use the power button either...
    I'm so confused!
    And all this money for something not working is making me !
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    Update...
    Pulled it into the house, and unplugged the M2-ATX. I plugged in regular PSU, and presto! Nothing. Now it won't even turn on.
    I tried a push button to turn it on, and I tried to short out the front header pins with a screwdriver (jewelers flat head, don't panic). I sometimes see a whirr of the cpu fan and a blink of light on the psu for the fan, but nothing. I'm beginning to think it's doomed...
    Mar 2006
    Alright, another update...
    The PSU I was using was a "smart PSU" that automatically neglects to turn on if it is not wired properly, including using the 4pin P4 plug that via boards dont have. So after figuring that out, I used a regular cheap thing out of a $20 case and back to booting and seeing life. The drive still had a read error though, so I am guessing that it is not M2-ATX related... Maybe harddrive. So reinstalling windows.
    Does anyone else know of why this read error came up. In all of my experiences, this has only happened 1 other time, and the hd had bad sectors. Could it be that my 250Gb is bad! Ohhhh noooo!
    Well. We'll try this out.
    P.S.: Someone could maybe move this to "General Hardware Discussion" now that it is not PSU related.
    Feb 2005
    West Valley City, Utah
    I am thinking a bad hard drive. Most have 3-5 year warrenties now, and being that its 250 gigs, you might fit into that range.
    Progress,.... that is what I keep forgetting ;)
    planning_[++++++++++]. 110%
    parts___[++++++----] around 60%
    install___[-----------] -9,000%
    Mar 2006
    That's what I'm thinking too... Doing a fresh install to be sure, and if persists, back to the manufacturer it goes!!!
