Results 1 to 10 of 17
Thread: Does your DSATX shut down after 5 blinks?
    Falls Church, VA
    5 blinks is an overload and has happened a few times with my current setup. I'm asking quite a bit of the unit. I have an older version and im curious if those with new versions have run into the same thing. When my unit goes into overload, I never know it as the PC is located remotely. This overload causes the DSATX to NOT shut down after 10 mins of no acc and i come out with a dead battery the next morning.
    Can anyone varify that the new version does not bypass the shutdown timer when overload (5 blinks) kicks in?
    Elsewhere
    I believe that is correct.
    I was having a similar issue. It would reboot once, usually sortly after I started the truck. I brought the PC inside and set the high voltage threshhold to 18.00v and the low voltage threshhold to 8.5v. Hopefully, that will resolve the issue.
    How about the Wiki?
    Apr 2001
    Portland OR
    Quote Originally Posted by DarquePervert
    What you are discribing is called the Fault State. The way to clear a fault state is to have ACC go low and the motherboards PS_ON signal to go high (deasserted). Next time you get into this state if you could measure the green wire with a DMM, that would tell me if your motherboard is still trying to turn on the computer keeping the fault state from being cleared.
    It's possible that when you get into this fault state, the motherboard is still pulling on the PS_ON signal. I could modify the code to just clear the fault with an ACC going low. The input voltage has nothing to do with the fault state. It is strictly based on wether the outputs of the DSATX are within 10% of the nominal voltage.
    railsGood = ((plus3_3A > 305 ) && (plus3_3A < 355 )) &&
    ((plus5A > 460 ) && (plus5A < 540 )) &&
    ((plus12A > 1098) && (plus12A < 1302 )) &&
    What kind of numbers is your diagnostic feed putting out for +5 +3.3 and +12. If they are at one end of this range, I might consider extending the allowable range. There is also 50ms of hysteresis so that it has to stay bad for that long before it will go into a fault.
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Apr 2001
    Portland OR
    Quote Originally Posted by Will Albers
    Will, I think your PSU might need to be updated with my firmware fix that can't be done remotly..
    -Jeff
    www.mpegbox.com
    Falls Church, VA
    Jeff, can i pay you a deposit plus shipping and have you send me out a 2nd unit? It can be a refurbed. I have no issue with that. When i get it I'll pull mine and send it back to you? Then refund the deposit?
    I'd like to get this done but i have a couple road trips coming up that I would hate to be "tuneless"
    In regards to your questions, I will keep an eye out but it can be tough to catch it when it overloads. I have been hibernating manually everytime i shut down the car. I will test next time i catch it.
    Newbie zenpoppa's Avatar
    Apr 2006
    Dallas, TX
    Okay, I just installed the 3 pin fan with my DSATX to stop it shutting down in this hotass summer, but now when I try starting the car and carpc w/ ACC I'm getting 5 blinks and whole lot of nothing. What can I do? I still have the same configuration as before, but the the new fan that is only using 1.5 watts. Help please.
    This is your life, and it's ending one minute at a time.
    Nov 2005
    Quote Originally Posted by zootjeff
    -Jeff
    Jeff,
    Exactly the same happens on my machine.
    1.The DSATX works fine.
    2. I shutdown the pc/it shuts down the PC
    3. Come back later and restart car (ie: ACC goes high)
    4. It calls a fault state (5blinks)
    5. I pull the Fuse to the DSATX (Because nothing other than removing VCC will relieve the fault.)
    6.Put fuse back in - PC boots as normal
    I'll try monitor that voltage and get back to you.
    But in my case, Id probably prefer (need) to have the Fault State ignore the PS_ON signal.
    I'll also check the MB turn on pins to see if its active high or low.
    Cheers.
    Apr 2001
    Portland OR
    Quote Originally Posted by Iceman_jkh
    Jeff,
    Cheers.
    I can make an update for you that doesn't look for PS_ON going low to clear the fault.
    www.mpegbox.com
    Nov 2005
    Thanks, that would be perfect
    And, in your opinion, easiest way to include a 'HARD OFF' switch = putting a switch inline with VCC (or one that switches a relay that passes VCC)?
    Reason:
    Poor soundcard drivers sometimes cause my PC to hang/play trashed sound at FULL VOLUME, so i need something to "immediate off" the system. I looked at the USEROFF header pins, but these ZERO the countdown timer when ACC is low, and the above situation has occured to me whilst doing 110Kph on the highway with no way to turn off ACC in a hurry.
    The switch will be in the ON state 99% of the time, but I need it just as a failsafe (might even make it a momentary one to act as a reset button instead).
    Apr 2001
    Portland OR
    Reason:
    The Reset switch sounds like the best solution. You'd need a 20 amp relay or a really beefy switch for a "Hard Off"
    www.mpegbox.com
  1. DSATX Power Supply on LV-673 MoBo
    By Caelric in forum Power Supplies
    Last Post: 12-17-2007, 03:21 PM
  2. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 08:47 PM
  3. dsatx issue
    By gameboy in forum Power Supplies
    Last Post: 02-25-2006, 04:12 PM
  4. DSATX review / Shuttle PSU mod
    By alti in forum The Review Palace
    Last Post: 10-11-2005, 01:34 PM
  5. OPUS 90W , I can not shut down my car-pc
    By scw5179d in forum Newbie
    Last Post: 05-05-2004, 04:25 AM
