Results 1 to 8 of 8
Thread: What kind of Fuse should a use?
    Una
    Una is offline
    May 2006
    Cool What kind of Fuse should a use?
    Hi Ive got a M1-ATX Power suply and my only question is how many Amperes the fuse should be? Is 10 Amp ok?
    Hope i get a answer quick so i can fix that tomorrow...!
    FLAC TheLlama's Avatar
    Jul 2004
    All over the world
    Quote Originally Posted by Una
    Hi I´ve got a M1-ATX Power suply and my only question is how many Amperes the fuse should be? Is 10 Amp ok?
    divide the wattage by the voltage and then add some. P = VI. As far as type, it is up to you: blade, littlefuse, whatever...
    Una
    Una is offline
    May 2006
    I beleve the Powersuply i 90 watts and im running on 12 volts.
    Would that mean i Need a 7.5A fuse? If so i just settle with a 10A?
    Jul 2004
    All over the world
    Yeah, 10 or 15A sounds good.
    _
    Mar 2004
    Little Elm, Texas
    isn't the fuse on the PSU a 10 amp fuse?
    Jan Bennett
    Jul 2004
    All over the world
    Quote Originally Posted by Red GTi VR6
    I don't know, I don't have a unit.
    _
    Mar 2004
    Little Elm, Texas
    ok - well that must mean the question wasn't directed towards you but rather the OP...
    Jan Bennett
    Jul 2004
    All over the world
    True, a rhetorical question at that
  1. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 11:01 AM
  2. low amp fuse blowing in MX radio adaptor
    By march09 in forum Car Audio
    Last Post: 01-06-2006, 06:53 PM
  3. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  4. Lilliput Lcd fuse blown help!!!!
    By fernando11554 in forum LCD/Display
    Last Post: 05-16-2005, 12:54 PM
  5. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
