Find out what wire the Compaq actually use and redo the connector.
The Compaq probably uses all the voltage rails of standard ATX.
Example: Instead of 5 wires for 5V, it only use 1 or 2 wires for 5V.
In short I bought the Opus 150 and discovered that the mother board on my computer (Compaq Ipaq SSF) is a 14 pin as opposed to the regular atx 20. The two threads I found that discussed this dead ended. Is there anyway to utilize the Opus with a non ATX board? I was thinking maybe using the wires from the power button. Or maybe using the built in shutdown controller from the Opus with an inverter? Any ideas on this?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Thanks for the response. I just talked myself down from getting an inverter. Here is the last post that this subject came up in Help with SFF Compaq Power Supply
I got the colors but I have no idea about "inverting the PS on signal from MB" thi is needed because Compaq uses positive logic to enable PSU. This is greek to me. if you have any thought PLEASE let know.
follow the circuit diagram in the second PDF, it shows you exactly how to connect everything including the opto couple along with the part number you need to get. I couldnt find the exact part but but I found several that would do the same job. Cheapest was 58p thats about $1.
Edit***
I found his website with a contact page if you want to ask him where to get the exact same part
http://ashsoft2000.tripod.com/index_files/Page345.htm
Great thanks for the reply. I was doing some research and it looks like what I need is a 4 channel optocouple. I am new to this electrical stuff but it seems to me if I show the diagram to a reputable electrical componant shop they should be able to give me a matching product. I'll go hunting tomorrow. Thanks again for ur help.
It looks as though the the part he mentioned TIL192 is discontinued, Also basd on the circuit diagram it looks as though i need a 4 pin the 192 looks like a 8. I beleive these will do the same thing TLP624 from Isocom or H11A617, the problem is I cannot find any place that sells them retail. Can you please let me know where you found the one that is about a dollar. Or what sort of store would sell this part. Thanks lotOriginally Posted by v8 scimitar
they were on www.Maplin.co.uk and http://rswww.com but I dont think any will ship to the US if thats where you are. If you are in the states then http://www.digikey.com/scripts/DkSea...653458&Site=US has the 624 for 96cents and will sell just one.
Edit***
ok digikey links from the search page dont work the above link is to a single channel toshiba 624 but if you go to www.digikey.com and enter the part number it will give you a few options.
Thanks alot for the information. I just ordered 3 (considering I have to buy a soldering iron I am anticipating some mistakes). I'll post once I have everything installed.
Okay got my optocouplers today. I am I am looking over ashsofts Diagram and I see a rectangle with 1k. What is that. I have never taken and electronics class in my life so please forgive my ignorance> Thanks
A resistor.
