Jan Bennett
It is wired like this:
+ line from battery to the m2-atx
- line to the same ground as the amp ground
+ line to the amp from the same battery
acc line to the m2atx
LCD monitor has the radio + line (in-dash instead of the radio)
and the ground line from the radio also
Everything is properly wired, as i revired everything because of the noise that was present. It all works perfectly, just that the LCD starts blinking when i listen to music loud
The amplifier is from Blaupunkt model GTA 250 two channel amp
ok - I was thinking maybe that amplifier was causing the problems, but at 100 x 2, I would HIGHLY doubt it...
sounds like you're having current draw issues.
are all of your grounds 100% secure? bare metal to bare metal, no paint. No frayed wires, none of that?
does it do it with the motor running v. not running?
Jan Bennett
It happens with the motor off and running.
The grounds are 100% secure...so are the wires...
Isn't it possible to be the lack of Power or smthn.? Maybe the batteries are to weak and i need another?
I highly doubt that.
a computer really doesn't pull that much, and you're amp is really small. If the stock Hyundai alternator can't keep up with this little but of additional demand...I would think there was another issue.
How old is your battery? What size is it?
Jan Bennett
Where is your carputer physically in relation to the amp and the sub? How did you run the power cables, and the computer monitor VGA cable?
Michael
I think its about 2 yrs old not more.How old is your battery? What size is it?
My carputer is right next to my amp (amp is for my speakers not for a sub)Where is your carputer physically in relation to the amp and the sub? How did you run the power cables, and the computer monitor VGA cable?
The power cables go through the left side of the car and my RCA cable ges through the right side of the car. No ground cable is longer then half a meter and is 100% secure.
where are your power cables run?
are they run along side signal cables?
and regarding the battery:
Originally Posted by Red GTi VR6
Jan Bennett
No they are run separate from the signal cables...
And about the size...i'm going to check it.
