Results 1 to 5 of 5
Thread: Power cap
    Jan 2006
    Exclamation Power cap
    hi there
    Im a bit new to the whole car pc world. i was just wondering does a dc-dc regulator not jus do the same job as a powercap. in other words can i use a powercap with a normal 12v dc powersupply hardwired to the batery
    thanks in advance
    regards
    Tom
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Voltage regulator and caps are 2 different things.
    Voltage regulator regulate the fluctuate voltage in the car between 8-15 volts and provide a set voltage (12,9,7.5,5,...) to the equipment.
    Power cap provide rush current to the equipment ( I may be wrong here).
    Is it okay to use power cap with a 12VDC power supply?
    If you are talking about M1-ATX, M2-ATX, Opus, DSATX as a 12VDC PSU, Yes, you can but not needed. Those PSU already have voltage regulators built -in. Just connect those PSU straight to the battery.
    You need to do some more reading buddy. Head up to the newbie forum (there is a sticky regarding new to carpc) and the FAQ forum. Those answers most/all question you will be asking regarding to the whole project. It make your life easier.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Newbie Phreak Show's Avatar
    May 2006
    Germany, Bavaria, Augsburg
    Quote Originally Posted by MatrixPC
    Nope, you're right. Caps are used to have a constant voltage if the current is switching very fast and/or in high amounts, for example if you have a huuuuge audio system in your car
    _
    Mar 2004
    Little Elm, Texas
    and even then y ou will need a HUUUUGE cap to make a damn
    Jan Bennett
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by Phreak Show
    Just to clarify...
    Capacitors are used to maintain sufficient current, not voltage. While the capacitor might have some stablizing effect on the voltage, the main reason they are used is because a typical lead acid storage battery (like a car battery) cannot respond to the large, instantaneous peak current demands of a power amplifier. Most typically, capacitors are used on subwoofer amplifiers, as they demand GOBS of current when the bass "hits" in rap, rock, or simliar music.
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. Power supply Problem
    By xGROMx in forum Power Supplies
    Last Post: 03-16-2007, 02:19 PM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
