Results 1 to 8 of 8
Thread: Does the PSU go to the battery or the distribution block?
    May 2006
    Calgary, Alberta
    So the 2 amps go into the distribution block with 1 wire going to the battery. If I try and put the 18 gauge computer power wire into the block, it's not going to fit in the 8 gauge hole. Do I just run it to the battery terminal?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Elsewhere
    You can get an adapter to get the 18awg wire into the 8awg hole...
    IF you're a DIYer, just solget a short piece of 8awg to the 18awg wire for the PSU and cover it all up with some heatshrink tubing.
    How about the Wiki?
    May 2006
    Calgary, Alberta
    I'm the kind of DIY that would do twisting and electrical tape! I'd make it real secure though, lots of tape.
    So I guess I have a new question.
    1. Has anyone seen a distribution block with 3 input holes? I've only seen 2 and 4.
    2. If I get the one with 4 holes, how do I block off one of the holes so nothing gets in there and catches fire?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    The blocks are usually designed to prevent shortage/fires from any unused ports (hence why resesed in plastic usually...)
    Like you said before....you could just tape it....
    If you are really worried...plug it with some plastic/non conductive material and secure with a bit of tape to cover or something....
    search a bit more...cuz i vaguly remember a 3 port 4AWG to 8AWG distro block...but for the life of me cant remember where i found it....it may have been by stinger audio...but i could also be making that up
    Brown 2010
    Elsewhere
    Quote Originally Posted by Maheriano
    Get youself a soldering iron. You can get a cheap one for $15 that will do whatever you need. In the heat of a vehicle in summer, the adhesive of electrical tape can melt away, allowing the tape to slide along the wires, exposing the joint.
    Crimp connectors are another alternative, but I'd much rather solder my connections and cover them with heatshrink tubing.
    To answer #2 - Use some electrical tape, since you now have the soldering iron and heatshrink tubing!
    Seriously, the terminals in the distro are set back into the unit enough that this isn't a big concern, unless a wayward Cheeto finds its way in there. I don't think Cheetos are conductive, so you're probably safe.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    this is one that will go down in history...lol
    "I'd make it real secure though..."
    tape = real secure?
    that's a knee slapper for sure!
    Jan Bennett
    Mar 2006
    NJ/RI
    What the hell is in a cheeto that would make it conductive!! Man im freaked now!
    And tape (Although not REAL secure) it can get the job done...
    You want to hear a real knee slapper....My buddy in his first install didnt cover any of the speaker joints with anything. Simply twisted the wire together and left it....now thats bad...
    Brown 2010
    _
    Mar 2004
    Little Elm, Texas
    hrmmmm....twisting wire together and leaving it....that sounds oddly familiar....lol
    Jan Bennett
  1. 2nd battery + computer controlled lighting
    By jparks27 in forum Show off your project
    Last Post: 06-02-2006, 09:52 PM
  2. Can a carpc psu be used to charge the car battery?
    By Yellowmann in forum Power Supplies
    Last Post: 04-17-2006, 08:26 PM
  3. DISTRIBUTION BLOCK cant find the right one
    By bginamercedes in forum General Hardware Discussion
    Last Post: 06-24-2005, 02:40 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. Distribution Block Questions
    By beckkl in forum Power Supplies
    Last Post: 10-20-2004, 12:29 PM
