Results 1 to 2 of 2
Thread: Noob question. Fake UPS...how to ground serial port?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Exclamation Noob question. Fake UPS...how to ground serial port?
    Hi.
    I am new to this carputer world, and I would like to try building one. I've been stalking these forums alot and I think I have a pretty good idea on what I need to do. However, I am confused on one part. For the fake UPS schematics, it says to apply +12v to pin 8 on the serial port. So with the +12v applied, where do I connect the negative terminal (ground)? I've searched these forums and I have not found anything useful. Also, once I configure the computer to hibernate with the fake UPS, do I simply go into the BIOS and enable the power on after power loss setting to make my computer turn on automatically once the inverter is powered on? Just making sure before I do anything. Advice would be appreciated. Thanks.
    Oct 2005
    Raleigh, NC
    The PC's case should be grounded to the car's chassis. Avoid ground wires used by the radio etc. Ideally, a thick, short cable to prevent ground loops. I'm using the switched 12V from my car to feed the serial port and it works great.
    good luck
  1. Can I pull out 200mA from serial port of Epia 10000?
    By slimmegane in forum Hardware Development
    Last Post: 10-24-2005, 11:25 AM
  2. winxp pro serial port lag
    By karhu in forum Software & Software Development
    Last Post: 06-07-2004, 01:16 PM
  3. NooB question
    By ouikikazz in forum Newbie
    Last Post: 04-19-2004, 02:34 AM
  4. UPS / Auto shutdown question
    By gizmomkr in forum General Hardware Discussion
    Last Post: 05-22-2001, 03:33 AM
  5. Question: Arise psu: ground, neg, and pos.....?
    By Tony S in forum Power Supplies
    Last Post: 05-02-2001, 08:54 AM
