Banned
My mini linear power supply..
Okay, I had this GREAT idea.. right?? to put a linear DC-DC PS into an old HD case.. and use the case for a heatsink.. does anyone see any problems with this??? the case should provide enough of a heatsink to draw 3amps continuous@5volts and 1.5continuous @ 12volts.. right??? this should ha enough to power a mobo, with external cards (2 or so) and a harddrive...... This idea would provide easy mounting of the powersupply.. and prevent shorts of the PCB, as you probably wouldn't need one... anyway, post your feedback, positive and negitive.. thanx..
Retired Admin
Sounds like a good idea to me, but don't waste time with linear. A switching supply would be best, and the form factor of the HD would allow a small fan to draw air through the whole case...
Banned
Well, I made one, using linear regulators, in a LAPTOP HD CASE!!! LOL!!!!!!!! works fine... only prob is that I was originally gunna use 2 5amp 5volt regulators, but using one generated ZERO noticible heat.. so, I am gunna rip out one of teh 5volt, and replace it with another 12volt low dropout (only rated @ 1amp) so as to have 2amps constant on teh 12volt, rather than 1amp, with I had and powered a HD, 48X cdrom, and a fan, and then something started smoking, lol... ahh, time for some pics I suppose, DODGY DIGITAL CAMERA!!!!!!! (not mine) (don't have one)
The masking tape on teh PS is becaseu I nolonger had teh screws..
Also, I thought I would pointout that I have ZERO sucsess in teh past with using 1084 12volt regs to give me a regulated output, even with input of around 14volts... This is why I chose lower power regs which give a regulated output of 11.8 volts with as low as 12.2 input... and, as teh volatge drops, teh output is teh same is the input, but with the 1084 regs, I got a drop of around 1volt between out and in when a lower input was used.. so, with this setup I am using, when cranking, teh battery voltage drops to no less than 10.5volts... this is therefor what the 12volt rail then is, and this is actually still enough to SPIN UP a hd, not just keep it spinning.. so, andone in Australia want to buy a sproggy PS without half teh diodes (I was unable to source these, or afford them, after my money went missing in teh post... lol)
Did you have a LF decoupling cap on the input & LF & HF decoupling caps on the output? These can make quite a bit of difference, especially the LF on the input.
Rob
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
Do you have the part numbers of the regulators you used? Also, do you have a wiring diagram? Thanks, that is exactly what I am looking for, 5V 5A and 12V 1A...
mike
Banned
Rob
Ahh..... I forget now, lol..
Well, the regulators I used were......
Hasn't this all been covered before or something??? anyway.. thay were:
5volts -
LM1084-5
12volts - LM2940C - 12
Or something like that, not too sure on teh 12volt one, but teh specs are right... can't check part number on teh ic now, can't find the PS.
Banned
Okay, I swapped one of the 5volt regulators for another 12volt regulator, but now I need 2 resistors to balance the output voltages... Will post results soon....
Retired Admin
Have you run a PC for any length of time with this supply? What was the heat output? I would be concerned that the HD case will simply act like thermal storage, and keep heating up without any real transfer to the air. Might be a good idea to bolt on an old CPU heatsink to each side...That will give more surface area and help keep the temp down.
Banned
Well, I powered a HD a cdrom and a fan for about half an hour, and then something started smoking, this was before I had 2 12volt regulators.... The HD case was evenly warm, and I couldn't even tell which chip was creating the heat, so it must conduct heat well.. Some time soon I will try it with the computer.....
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
