I have no idea what 8g 4g is as we use mm so cant help with fuse ratings but I can with position. Fuses are there to protect the cable not the apliance as they have their own just like your M2 has a 15A on the board, this is for the M2 and wont protect your cable. You must fuse at the start of any cable run. So from battery to DB you need a fuse at the battery form DB to powersupply it needs to be fused at the DB if the DB doesnt already have fuses built in. Reason being if something hapens the the cable, say the cable got traped and shorted to ground just before the power supply it wouldnt be protected by the M2 fuse so it would go on fire if the short was bad enough.
Hope that makes sense to you if not then just shout and I will try and explane a bit better.
LinkBack URL
About LinkBacks
