Results 1 to 5 of 5
Thread: LCD and AMP remote on with M2-ATX
    Variable Bitrate debugger's Avatar
    Mar 2006
    CA
    Can I use the same J6 connection on M2-ATX to send a remote turn on signal to both touchscreen LCD and the AMP at the same time?
    Jun 2006
    Probably... As long as your connecting to the "remote" wire of the amp.
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    Quote Originally Posted by debugger
    I'd run that remote signal through a relay, and then use the relay to power the amp and LCD remote lines, if I were you.
    The M2 seems to be fairly sensitive to excess current draw in general (look in the power supply forum for stories about M2 failures, and you'll see what I mean). If you don't know the current draw of the remote lines for your LCD and amp, then you run the risk of drawing too much current from the M2's remote output, and frying the M2.
    It'll probably work just fine...but better safe than sorry, from my experience!
    Jun 2006
    Good point, and it definitely wouldn't hurt it either. Better safe than sorry. Burned up components suck...
    -Patrick
    Mar 2006
    CA
    Quote Originally Posted by parksgm
    Relay? A button or... what are the specs?
  1. Motorised LCD with amp?
    By DangerMouse in forum LCD/Display
    Last Post: 04-14-2006, 05:19 PM
  2. How close can a lcd be to a Amp?
    By thanatos106 in forum Car Audio
    Last Post: 05-13-2005, 10:59 PM
  3. Can Opus 90W remote turn on AMP and LCD >
    By Gibbon in forum Power Supplies
    Last Post: 10-16-2004, 09:57 AM
  4. lcd and amp question?
    By sanbas in forum LCD/Display
    Last Post: 08-05-2004, 12:35 PM
  5. 5.6" LCD, PCI TV/Radio, 7.1 sound card, Sony amp & more
    By eatyummypuppies in forum Classified Archive
    Last Post: 06-29-2004, 08:19 PM
