Results 1 to 10 of 16
Thread: Is It Bad If An Inverter Is Always On?
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    If I wire my PC up to an inverter, and have my inverter ALWAYS ON, is that bad? I dont think it drains my battery since I ran it over night (12+ hours) and my car started in the morning with no issues at all... My battery level on my gauges was normal and everything...
    Because if my inverter is always on, then I can just have a relay hit my power button on my PC when the ignition is set to ON, and hit the power button again when the ignition is set to OFF... Yes?
    Thanks in advance for any help...
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    I think it really deppends on how you wire it up..
    if it is connected to the LIVE (directlly to the car batt.) then it will eventually drain your power.. an inverter is like any other tranformer.. when it is plugged and not used half of the circuit is in use (correct me someone if I am wrong).
    I bet it even gets a little hot when it is plugged and not used...heat=energy=power from battery..
    Elsewhere
    It will eventually drain the battery, yes.....
    How about the Wiki?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Other than running down the battery, nothing really bad about leaving it on.
    Well, it's always better not to have a live 110V wire laying in the car.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Elsewhere
    <SARCASM> But live wires are such FUN! </SARCASM>
    How about the Wiki?
    May 2006
    Calgary, Alberta
    Why don't you just run the power to your fuse panel? It takes 2 minutes.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Nov 2005
    Dallas, TX
    Thanks guys for the replies...
    The way I see it is your going to have a live wire when the car is moving anyway, so why not have it when the car isnt moving at all... That would be safer, yes? But either way, i get your points....
    A question though: I have a car alarm installed, doesnt that take power aswell? I mean I would think that the tiny fan on the inverter wouldnt draw that much power... I would have to compare it to my alarm if anything....
    Also, I dont want to run it to the fuse block because I am trynig to figure out ways to bypass a SDC basically... The only SDC that I have found that would work with an inverter properly is the "Ghetto SDC" in the FAQ area, and I dont like the way it is set up. So I am trying to figure out other ways of doing what I need my carputer to do: startup and shutdown with key.
    Either way, thanks for the input
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    May 2006
    Calgary, Alberta
    What's a SDC?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Elsewhere
    Quote Originally Posted by Maheriano
    What's a SDC?
    Shutdown Controller.
    For future reference, there's a glossary in teh FAQ Emporium: FAQ: Glossary of Terms
    How about the Wiki?
    May 2006
    Calgary, Alberta
    It's called an add-a-circuit. It's a fuse with a wire going into it, specifically designed for wire-fuse input. And the fuse has a fuse holder on the back of it, so the fuse slot you're using can be occupied by both the fuse that came out of there and the wire you're feeding into there. I'm using one, it takes 2 minutes.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Weird Inverter Issue
    By Noodleman in forum Power Supplies
    Last Post: 04-05-2005, 05:25 AM
  2. 150w PC 300w Power inverter... help?? Please..
    By MINI-Cooper-S in forum Power Supplies
    Last Post: 03-16-2005, 07:25 AM
  3. custom shutdown controller for inverter usage
    By Vchat20 in forum Power Supplies
    Last Post: 02-28-2005, 11:59 PM
  4. Inverter Question
    By PapaPrem in forum Newbie
    Last Post: 02-22-2005, 01:46 PM
  5. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
