Results 1 to 10 of 19
Thread: What's the deal with the M1-ATX J2 Connector?
    May 2006
    Calgary, Alberta
    I have this question going at the end of another thread but it didin't get looked at and I also emailed the MP3car store. I also read through all of the other posts regarding it and I pretty much know what I have to do, just not how to do it. So here's what I have.
    Now I know I have to plug the J2 connector in the middle into only 1 of the 2 pins and it's the red wire that has to be connected on the cap side. But how do I do that? It only connects 1 way, I'd have to either cut the wire or shave the plastic so it'll fit only on one pin. What do I do? I want to hook it up tonight.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    buuump.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    Nobody? Can I move along with my project for now by leaving it unhooked until I get an answer? I really want to get it running and check out the GPS somewhere other than my living room.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I'm not sure I really understand the question...
    Why not just cut one of the wires instead of shaving stuff?
    Tidder
    Try RevFE
    Sep 2003
    New Mexico, USA
    Yeah, just cut the stupid black wire so you're only using the red. That's all you need. This is the amp on wire correct?
    EDIT: I can't really tell which color wire is going to the pin next to the cap, but it looks red to me, if it's the black wire, just use it and cut off the red.
    Tidder
    Try RevFE
    May 2006
    Calgary, Alberta
    Yes, remote lead to amp. So it's fine just to cut the black wire and that'll stop it from frying it like other people have done?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Sep 2003
    New Mexico, USA
    Yeah, your black wire is just hooked up to ground. That's all that other pin is.
    Tidder
    Try RevFE
    May 2006
    Calgary, Alberta
    Has anyone pinpointed yet why the ground fries it?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Sep 2003
    New Mexico, USA
    Beats me, I have an M2, dunno if it's the same, but don't want to try.
    Tidder
    Try RevFE
    May 2006
    Calgary, Alberta
    How do you turn on your amps?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. powering a VIA MII w/ a ATX powersupply
    By boostedGT-S in forum Power Supplies
    Last Post: 01-20-2005, 01:57 PM
  2. Replies: 5
    Last Post: 11-16-2004, 10:08 PM
  3. Opus 150 watt ATX Connector
    By bjm2020 in forum Power Supplies
    Last Post: 07-25-2004, 05:39 PM
  4. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
  5. ATX PSU from m2pc.com / to jjohnson
    By r0cket- in forum General Hardware Discussion
    Last Post: 12-20-2000, 03:00 PM
