Results 1 to 10 of 11
Thread: DSATX programming mode
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    hey, i can no longer get the DSATX into spitting out diagnostic information, actually trying all the commands the only thing it will do is @ (shutdown signal to computer)
    any ideas? do i need to open it up and do the jumpy thing to reset to factory defaults?
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    Elsewhere
    I've had to do reset it a couple times....
    What jumpy thing?
    I just had to cut 12v to it a couple times and hook the branstem up to another PC (my laptop) to reset defaults.
    How about the Wiki?
    May 2005
    Elizabeth City, NC
    Quote Originally Posted by DarquePervert
    What jumpy thing?
    that did not work for me, tried that a few times earlier today
    jumpy thing - short the jumper at A, i think it was....would have to double check.
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
    May 2005
    Elizabeth City, NC
    okies, i have had no luck what so ever in getting into programing mode( it use to work, that's how i set it up orig.)
    i get no diagnostic output(yes i am using all upercase letters)
    the only thing i can get to work is @ ( simulated power button press)
    other then that, nothing this is what i've done
    1) removed all power wires from dsatx
    2) shorted the reset jumper(tried this shutdown/powered up/unplugged no difference)
    3) unplugged the brainstem/serial cables
    all results return the same result - nothing
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
    Elsewhere
    Then try D to reset to defaults, then try E
    It's an undocumented function that will enable writing to the DSATX.
    How about the Wiki?
    Apr 2001
    Portland OR
    Its not Undocumented.. It's in the manual..
    http://www.mpegbox.com/pdf/DSATX_Manual.pdf
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Elsewhere
    Quote Originally Posted by zootjeff
    Sneaky! You updated the manual!
    That's a good thing, though....
    How about the Wiki?
    May 2005
    Elizabeth City, NC
    found *part* of the problem
    for ****s and giggles, i took out the serial cable and plugged it into a cable tester. it has a few broken wires, upon closer examination, i found that 3 wires were not soldered in very well into the db9 connection. tommorow i'll see about locating a replacement cable, i will update post accordingly
    (fyi - TX works RX does not !)
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
    May 2005
    Elizabeth City, NC
    also, as a note, i'm still getting a dead battery from time to time, i really need the dsatx to FORCE OFF after x minutes. or X voltage....
    95 Mazda Protege LX
    Worklog
    2003 Nissan Altima
    Worklog
    Elsewhere
    IT should do that by default.
    Mine has a 300sec (5min) shutdown timer and a hard off after 1min.
    How about the Wiki?
  1. Lilliput Programming Guide, More Reset Codes
    By Anointed in forum LCD/Display
    Last Post: 07-15-2011, 09:28 PM
  2. Quest for 800x480
    By ptk in forum LCD/Display
    Last Post: 01-04-2010, 11:42 AM
  3. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
  4. Does XM mode operate as 'RADIO' mode
    By rjoek in forum Road Runner
    Last Post: 07-07-2005, 11:18 AM
  5. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
