Results 1 to 7 of 7
Thread: DSATX F1&F2 Amp hookup
    Low Bitrate dsballer2000's Avatar
    Oct 2005
    Canada
    Does anyone have this feature hooked up? I don't know exactly how this is done. I want my amp to turn on after my pc turns on. Do you just run the F1 cable (12v) to the REM on your amp and then ground F2? I may be totally off but if someone can help me out than I'd appreciate it.
    Thanks!
    Oct 2005
    Canada
    NM found my answer
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by dsballer2000
    NM found my answer
    If you found your answer, it great to post the solution to share it with others.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Oct 2005
    Canada
    Oops, sorry...It turns out that the F1 position(12v) just goes into the REM(Remote) in the amp. This will then turn the amp on after it turns on the computer which in return removes the loud popping noise that is made if its the other way around(amp on first, then pc). Also, when the computer is shutting down the DSATX will shut the amp off first and then the pc which eliminates the popping noise while the pc shuts down.
    Apr 2001
    Portland OR
    Wait a minute where did you find that?
    The F1/F2 is an open collector output. It will only pull to ground.
    http://www.mpegbox.com/microsdc/usdc20d_AuxOC.pdf
    Thats what you need to do. I also offer a kit for this.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Oct 2005
    Canada
    What's the kit like? and what does it cost?
    Thanks btw for clearing this up.
    Apr 2001
    Portland OR
    The kit is just like this:
    http://www.mpegbox.net/fourms/viewtopic.php?t=24
    5 bucks.
    www.mpegbox.com
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. My DSATX 220w experience
    By tj!2k4 in forum Power Supplies
    Last Post: 11-16-2006, 09:47 PM
  3. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 08:29 PM
  4. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
