Results 1 to 10 of 14
Thread: PC/AMP Issue
    Jan 2006
    Manchester, England
    PC/AMP Issue
    Hey all,
    I have finnaly got my Carpc up and running after a few duff power supplies and lack of time!!
    I decided to keep the stock HU and install an amp to get the sound from my PC. This is where my problem lies.
    I am powering both the AMP and PC from a 12v+ direct from the battery (fused) with a distro block on the other end to split the power.
    I have 2 wires running from my 12v switched radio harness wire, one to the PC one to the amp.
    Problem: If i try with both connected to this wire the AMP starts but the PC doesn't. When i disconnect the AMP wire the PC starts. I tried to add a switch to the AMP wire so once the PC has started the AMP can be flicked on manually, but this in turn switches off the PC!!
    Does anyone have any ideas how to work around the issue?
    Thanks in advance for your help
    Regards
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    maybe throw a relay in there off your 12v switched from your radio, and hook it to your 12v from battery. Use the relay for your PC, leave your amp directly on the 12v switched.
    Are you saying the 12v switched off your HU as in the remote turn on? Or what 12v switched is this exactly?
    Tidder
    Try RevFE
    Jan 2006
    Manchester, England
    Quote Originally Posted by Tidder
    Yeas Tidder it's the 12v switched i.e remote turn on to my HU.
    Sorry i'm not too familiar with relays. So the +12v from my battery and the switch 12v from my radio go into the relay and also wire to my pc?
    Thanks for the quick response!
    Jan 2006
    Manchester, England
    Just found this:
    Using a Relay to Turn On an Amplifier
    Steps:
    1. Connect the remote-on lead from the head unit to pole 85.
    2. Apply ground to pole 86.
    3. Put positive voltage from the battery to pole 87.
    4. Attach the amplifier turn-on lead to pole 30.
    I assume this will be the same for switching on the PC?
    Do i need to splice into my HU wiring in order to connect to the relay poles?
    Low Bitrate dfk70's Avatar
    Sep 2005
    Sterling, VA
    What gauge wire are you using for your +12V for the PC and the amp?
    2003 F-150 Harley Davidson Edition
    "The horse is here to stay, but the automobile is only a novelty - a fad." --- Marshall Ferdinand Foch, French military strategist, 1911
    Sep 2003
    New Mexico, USA
    Yeah, that's it exactly.
    You'll have to splice off your remote lead, that's it.
    Tidder
    Try RevFE
    Jan 2006
    Manchester, England
    Quote Originally Posted by dfk70
    For the +12v i'm using 8 gauge and i think 12 for the 12v switched
    Jan 2006
    Manchester, England
    Ok cool. Lastly is there another pole on the relay to connect my HU back up ,as i still need that to work!
    Sep 2005
    Sterling, VA
    Quote Originally Posted by Lewis187
    That should be ok. Use a relay to turn on each item and you should be ok.
    Here is some good info on relays: http://www.the12volt.com/relays/relays.asp
    Sep 2003
    New Mexico, USA
    No, you shouldn't have to disconnect anything from your HU. Just splice off the wire that's already there. It doesn't need hooked up to the relay.
    Sorry, this whole time I was speaking in terms of the remote on wire coming from your HU. The 12v switched wire leave hooked directly to your HU. Just splice off of it for the relay.
    Tidder
    Try RevFE
  1. Boot issue
    By Slippin3 in forum Power Supplies
    Last Post: 02-07-2006, 02:19 PM
  2. MII12000 pci issue
    By (6) in forum General Hardware Discussion
    Last Post: 11-24-2005, 12:46 PM
  3. iGuidance Hibernation - Interesting Issue
    By Troy McClure in forum GPS
    Last Post: 06-11-2005, 03:16 AM
  4. Issue with the radio?
    By l0gic in forum Road Runner
    Last Post: 05-07-2005, 05:44 AM
  5. More of a PSU/Inverter issue
    By slasherx in forum Power Supplies
    Last Post: 08-11-2004, 07:14 PM
