Results 1 to 5 of 5
Thread: Opus and Shutdown Timeout
    Frisco, Texas
    I'm preparing to purchase a Yellow-Top (deep-cycle) battery to give me some good safe "off engine" time. I want machine to stay on for File Sync and the quick stops at the grocery store..
    Part of that is implementing the delayed shutdown features of the Opus.. A couple questions....
    Is it dependable or flaky? Does it ever fail? Opus has no problem shutting me down with 10 secs, but I have to be able to depend on it when I'm not there to see it shut off.
    Would there be any problem with shorting 20 minute pins with a Toggle, to make delay/no-delay switchable?
    FLAC ppgt94's Avatar
    May 2001
    USA
    I've had mine set to 20min for at least 3 years now. I've never had a problem with the PC staying on. Of course I've never had the system hang during shutdown by manually shutting down either. The Opus is pretty reliable though. Although I would make sure you don't have any issues that might cause hangs during shutdown to begin with. Shouldn't be too much of a problem with a second battery anyway. Opus has the low-voltage kill power feature as well.
    BTW, I have a Yellow top installed as a second battery for the carPC. I can't tell you how great it is to be able let your system on Standby for days and not worry about trouble starting your car
    Frisco, Texas
    Think shorting the relay jumpers with a Toggle would cause a problem? How about if it was Toggled under power (during operation)?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    You might want to consider just using a toggle on your accessory line to the Opus. You could toggle between the cars ignition switch and a steady 12v. That way you don't have to worry about frying the Opus.
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by binary.h4x
    But then you would have to shut her down manually...
  1. Replies: 5
    Last Post: 04-24-2006, 04:16 AM
  2. OPUS: how to restart the carpc after manual shutdown?
    By kingtut in forum Power Supplies
    Last Post: 09-21-2005, 10:36 PM
  3. Opus 150W shutdown problems
    By migel628 in forum Power Supplies
    Last Post: 08-19-2005, 02:31 PM
  4. Changing Opus delay shutdown on the fly
    By Pepe in forum Power Supplies
    Last Post: 05-12-2005, 11:07 PM
  5. Can you adjust shutdown voltage on Opus 150w?
    By Visual Echo in forum Power Supplies
    Last Post: 03-26-2004, 09:04 AM
