Results 1 to 6 of 6
Thread: ACE-870C dc-dc power supply
    Apr 2005
    Hi all
    I just got a ACE-870C dc to dc power supply
    http://www.aplus-sa.com/us/showprod....rm=5&fbr=&div=
    It's just like any other pc power supply, just hooking up 12Volts doesn't turn it on. I was wondering what pins need to be jumped to turn it on.
    It has a harness to plug into a otherboard BUT I'm using my laptop, so I plan to draw power from the molex connectors 12V and 5V
    also this DC to DC power supply is setup to accept 24 volts input.
    I was wondering if there is a way to mod it to accept straight 12 volt
    thanks
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Input voltages: 18 to 36 VDC - 6A@24VDC
    Read the specs.
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Apr 2005
    I did, even tough it will accept the range 18-36vdc, it's labled the 24V unit. 18v is the VERY minimum, and 36v the very maximum.
    12V is still outside of that minimum limit. I don't think it'll on until it sees 18V minimum
    Feb 2001
    You will need to convert 12V to 24V. (Or at minimum 18V)
    It looks to be a AT type PSU, so all it should need it a load.
    ODYSSEY
    Digital-Car UK|
    (\__/)
    (")_(")
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    You are better off getting a 12v power supply. Transforming 12v to 24v , you will need a regulator , and a regulator wont supply enough amps for a power supply.
    Or you can put 2 batteries in series, but then how would you charge them?
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Yeah, by the time you build or buy a power supply to convert 12v to 24v to power it, you could have simply purchased a power supply that directly gave you the 12v and 5v outputs that you need... like the CarNetix CNX-P1290 for sale in the mp3car store.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  1. FS: 250 watt DC to DC Power Supply
    By EsKALad in forum Classified Archive
    Last Post: 11-11-2005, 08:58 PM
  2. Replies: 0
    Last Post: 02-09-2005, 03:49 PM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Replies: 8
    Last Post: 11-04-2003, 12:03 PM
  5. what is the cheapest DC to DC ATX power supply available?
    By Squeezer in forum Power Supplies
    Last Post: 07-29-2002, 02:17 PM
