Results 1 to 10 of 18
Thread: Solar Panel(s) as power while car is off
    Mar 2006
    Would a 10 to 15 watt solar panel act as enough to counteract the battery drain by a computer in standby?
    Other than that, would there be any benefits of a solar panel recharging the gas powered car's battery?
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Well, does your setup need 10-15 watts or more?
    Since there exists 10 watt solar panel trickle chargers for car batteries, I would assume that if you set it up correctly, it shouldn't harm anything (though I'm uneasy about the idea of constantly recharging).
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    yea it would help. might not be 100% tho cuz of clouds and what not.
    but when the car is on you should disconnet the solorpanel, so like with a relay to ign.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Elsewhere
    Your system in standby isn't going to draw anywhere near to that.
    Sure, the solar panel idea will work, but you wouldn't need it unless you park your car for extended periods of time....
    How about the Wiki?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    What about when it's standing by overnight?
    Want to:
    Elsewhere
    Quote Originally Posted by Bugbyte
    It still shouldn't dar enough power to drain your battery....
    Now, if you have TWO computers in your car in standby, it might not make it through the night...
    How about the Wiki?
    Jan 2005
    You get a lot of sunshine overnight there in VA?
    _
    Mar 2004
    Little Elm, Texas
    there have been people use solar panels in SQ comps for bonus points. We all know that they are absolutely useless. in order to get enough juice to charge your battery you would have to have a HUGE solar panel.
    If you just want to trickle charge it while it's in the parking lot at the air port say, then sure, it's possible, the VWs came with them for a while, I've got one even.
    Else, you're looking at a VERY expensive, very large panel for something like this.
    Jan Bennett
    Elsewhere
    I think that was the idea....
    If he has a
    PC in standby mode, using a trickle charge to keep the battery at a full charge while the PC is in standby mode...
    Again, I think it's a workable solution in theory. In real-world use, I don't know. It's certainly an interesting idea.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    I'll put it this way, the VW solar panel that VW released to be used on their cars while in the lots waiting to be sold, was about the size of a normal sheet of paper. You would probably need one larger to cover the carPC drain on top of other electronics. Where would you put that? How would you secure it? How would you make it look nice and not like some ghetto rigged piece?
    Jan Bennett
  1. Powering car from a 13.8V power supply ok?
    By PURDooM in forum Power Supplies
    Last Post: 06-12-2006, 11:56 AM
  2. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  3. Replies: 2
    Last Post: 07-21-2005, 12:07 PM
  4. FS!! Audioforge Car Power Package PSU!! $80!!
    By hyperspeed in forum Classified Archive
    Last Post: 06-26-2004, 05:07 PM
  5. FS: Morex Car Power Regulator Kit (Brand New)
    By migel628 in forum Classified Archive
    Last Post: 04-06-2004, 11:26 PM
