Results 1 to 10 of 10
Thread: Lilliput TC1000 12V Power Cable
    Jul 2006
    G'day All,
    Am new to this forum so hopefully I've come to the right place!
    I have a Lilliput TC1000 and the 12V Power Cable that came with it is 5 core however the colour of the wires don't match up with whats in the user manual.
    Here's a picture of the cable...
    This is what the user manual says each one is for;
    - red one to +ve power
    - black one to -ve power
    - white one to automobile electric control lock (ignition I assume?)
    - blue one to ground
    Now first of all they have only listed four.
    Second there is no white or blue lead.
    So which one goes to which???
    I'm guessing that the red and black ones where there is only 2 pins on the top row is the +ve/-ve to the battery, but the other 3 pins I don't know which is which.
    Any ideas??
    Cheers,
    Paul.
    Sep 2005
    scotland
    looks like the 2 black are grounds
    the 2 reds are live
    and the brown is acc from your car
    Constant Bitrate soundoff's Avatar
    Jul 2004
    AUSTRALIA
    same guess as me
    anyone actually own one and has wired it up? Its jsut a VIA TC1000 mainboard
    Jul 2006
    Why would they have 2 wires for power though?
    Newbie OmegaAvenger's Avatar
    Apr 2006
    Austin Texas
    Look at the ATX plug for a motherboard, it has multiple wires for each voltage. Its primarily to cut costs I believe. You spead the current across multiple smaller wires instead of one large wire. That or it may be two idependent circuits powered from the same plug
    Low Bitrate Gamer64's Avatar
    Feb 2006
    Holland
    The other 2 (red and black) are outputs. At least, that`s where i used them for.
    Jul 2006
    Gamer64,
    What did you use these for? Output to what?
    Cheers,
    Feb 2006
    Holland
    I don`t remember exectlay what i hooked up to them. But you could hook up your monitor to them. If u want constant 12v on it.
    Newbie locutusmouse's Avatar
    May 2008
    Scotland
    Hi Guys
    Same problem as Paul75. My power lead has 6 wires - 2 yellow, 2 black, 1 green & 1 red. Pin 1 is green, pin 2 is black, pin 3 is yellow. The red is above the green and black above black, yellow above yellow. Any ideas?
    May 2008
    Scotland
    I e-mailed Lilliput and they sent over a new manual which has the six wire power lead. The following picture makes a lot more sense. The green one I have also put to ground that way, as you will know, it works while driving (the whole point of our hobby) if not it will only work when the handbrake is applied
    I trust everyone, it's the devil inside them I don't!
  1. Auto Power On 619 Lilliput - Programing Guide
    By Anointed in forum LCD/Display
    Last Post: 10-23-2010, 06:26 AM
  2. Replies: 13
    Last Post: 09-19-2005, 01:02 PM
  3. Replies: 32
    Last Post: 05-05-2005, 11:49 AM
  4. 12V line power requirements
    By rushnrockt in forum Power Supplies
    Last Post: 03-08-2005, 02:02 AM
  5. Xenarc - USB Power cable?
    By Coeus in forum Power Supplies
    Last Post: 01-13-2005, 09:07 PM
