Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: The Ultimate Powersupply!!!
    Banned
    Jun 2001
    Adelaide, Australia
    I have come up with the ultimate powersupply for you carmp3player... This powersupply will take up ZERO space, so you can make the case even smaller!!! It will cause no heat problems... The cost is also very close to ZERO!!!! how you may ask??? well, it simple.. use a linear powersupply, and mount it on a largish heatsink... STUCK UNDER THE HOOD!!! lol.. just run teh individual 3.3, 5 and 12volt lines to the back(or front) of the car where the player is... Heat generated by the 5 and 3.3volt regulators will only be a problem to themselves.... and even then, you could have a massive heatsink.... What do you guys think of another of my KEWL ideas?? lol
    Dec 2001
    engine heat may be an issue... The trunk are would probably work better. Problem #2 is when its very sunny the body gets hot!
    Banned
    Jun 2001
    Adelaide, Australia
    Well can't teh regulators withstand upto like 150degrees Celcius or something?? anyway.... mount the heatsink near the front of the car to get air.. simple lol
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    1) It doesn't take up zero space, it just takes up space elsewhere.
    2) How about you build it and then come back and show us it can be done.
    Rob
    Banned
    Jun 2001
    Adelaide, Australia
    I am in the process of making it.... Just need time.. lol Will have probably 2 or 3 5volt regulators (5amp) and maybe 1 12volt 5amps regulator (if I can get it to regulate properly) or 4 1amp 12volt regulators....
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    One word springs to mind, Rain under the hood is will be exposed to all kinds of crap. Water spray, grit, oil etc. You'll need to put it in a sealed box, hence no cooling from the air.
    Rob
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    Banned
    Jun 2001
    Adelaide, Australia
    Rob
    Nah, the warmth from the engine and regulators will evaporate the moisture quickly... Linear regulators are pretty rugged, and should survive alright in the bad conditions..... the heatsink is aluminum, so it won't rust.. it should be fine...
    Jan 2001
    Adelaide, SA, Australia
    Re: The Ultimate Powersupply!!!
    Originally posted by THEMP3KID
    ...lol.. just run teh individual 3.3, 5 and 12volt lines to the back(or front) of the car where the player is...
    I would hate to think of the power loss of running the 3.3, 5v etc over a very long distance, unless you are going to run it through 4ga wire
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Banned
    Jun 2001
    Adelaide, Australia
    Re: Re: The Ultimate Powersupply!!!
    Hmm, shudup.... it'll work well enough for me...
    FLAC Mastero's Avatar
    Aug 2001
    India
    MP3kid it sound like a good idea...!!!
    Matter of fact since you put your PSU under the hood why dont you even try to make the Heat sink "WATER COOLED" like put the Regulators on a aluminum pipe and run water through it or even better run coolant ....!!!
    Think about it
    Mastero
